Compaq S710 Monitor - Overview
Product Description
Compaq S710 17-inch CRT Monitor
Color multiple scan with Invar Shadow Mask
Product Features
Specification
Standard Features
  • 17-inch (43.18-cm) color CRT with a 16.0-inch (40.64-cm) diagonal, viewable image area
  • Support for 800 x 600 display resolution at 109 Hz and a maximum
  • 1280 x 1024 display resolution at 64 Hz
  • Horizontal dot pitch of 0.23 mm
  • Capability of accepting the USB module option using an optional adapter
  • Asset control, allowing a network administrator to track monitor inventory by serial number
  • Energy Saver utility that reduces power consumption, lowers electromagnetic emissions, and promotes environmentally safe sourcing and recycling
  • MPRII compliant
  • Multisynchronous support for 10 factory-preset display modes
  • Plug and Play readiness that saves time in setup and configuration with Microsoft Windows operating systems
Color Monitor
Yes
Tube Type
17" Flat Square
Invar Shadow Mask
Yes
Viewable Image Size
16.0" / 40.6 cm
Horizontal Dot Pitch
.23 mm
Trio Dot Pitch
Opal monitors 0.27 mm
Carbon monitors  0.28 mm
Aperture Grille Pitch
n/a
Preset Modes
10
Max/Preset Refresh at 1920 x 1440
n/a / n/a
Max/Preset Refresh at 1800 x 1440
n/a / n/a
Max/Preset Refresh at 1792 x 1344
n/a / n/a
Max/Preset Refresh at 1600 x 1200
n/a / n/a
Max/Preset Refresh at 1280 x 1024
64 Hz / 60 Hz
Max/Preset Refresh at 1024 x 768
85 Hz / 75, 85 Hz
Max/Preset Refresh at 800 x 600
109 Hz / 75, 85 Hz
Max/Preset Refresh at 640 x 480
120 Hz / 60, 75, 85 Hz
Max/Preset Refresh at 640 x 350
120 Hz / n/a
Mac Mode: 1152 x 870
75 Hz
Mac Mode: 832 x 624
75 Hz
Short Neck
No
Dual Video Inputs
No
Anti-Reflection
Yes
Anti-Glare Coating
Yes
Anti-Static
Yes
Ambiant Light Sensor
No
Power Supply
Universal/Auto Sensing; 90 to 127 & 195 to 265 VAC;47.5 to 63 Hz
Max Power Rating
120 W
Power consumption (Suspend/Sleep)
10 W / 5 W
Input Impedence
75 Ohms
Signal Cable
15-pin miniature D-sub
Dimensions (HxDxW) (US/Metric)
14.25" (36.18 cm) x 16.6" (42.0 cm) x 16.2" (41.1 cm)
Weight (US/Metric)
34.6 lbs./15.7 Kg
Operating Temperature (US/Metric)
10 - 40° C
Operating Humidity
20 - 80 % RH
Swivel
± 45° from center
Tilt: (up/down)
15° up / 5° down
Certifications: MPR-II Compliant
Yes
Certifications: TCO'99
No
Certifications: UL Listing
Yes
Certifications: ISO9241-3 VOT Guidelines
Yes
Certifications: FCC
Yes
Certifications: CE Marking
Yes
Certifications: GS Marking
Yes
Certifications: Energy Star Compliant
Yes
AssetControl
Yes
Fault Management
No
Plug & Play
Yes
Plug & Play Protocol
DDC2Bi
The S710 Monitor is supported by the Compaq Three-Year Limited Warranty. The warranty covers parts and repair labor for three years. Field labor and onsite repair is covered for one year.
United States: The S710 Monitor is also eligible for the 48-Hour Monitor Direct Replacement program. This level of coverage is provided at no additional cost to the end user and is considered part of the standard warranty of the product.
Country: Flag Vietnam
