Evo Notebook N400c - Operating the Setup Utility
Overview
The system uses a Compaq BIOS.  The Setup Utility is used to change the system BIOS configuration.
Starting Setup Utility
To use the Setup Utility:
  • Turn on or restart the computer.
  • When the blinking cursor appears in the upper-right portion of the screen, press F10.
  • Select a task from the following menus: File, Security, or Advanced.
Closing the Setup Utility
To close the Computer Setup utility:
  • Select the File menu.
  • Choose either Ignore changes and exit or Save changes and exit, and then press Enter.
  • When you are prompted to confirm your choice, press F10.
