Evo Notebook N400C - Battery Technical Specifications
Li-Ion Battery Pack Specifications
Battery
Primary Lithium Ion
External Lithium Ion
External Lithium Ion High Cap
Height
.78" / 20 mm
.9" / 23 mm
1.8" / 46 mm
Width
9.06" / 231 mm
10.47" /266 mm
10.6" / 269 mm
Depth
1.84" / 47 mm
.9" / 23 mm
1.2" / 30 mm
.49 lb / .22 kg
.48 lb / .22kg
.93 lb /.42 kg
Cells
4
4
4
Voltage
14.4 V
14.4 V
14.4 V
Amp-hour Capacity
1.96 Ah
1.96 Ah
2.87 Ah
Watt-hour Capacity
28 Wh
28 Wh
349 Wh
Operating Temperature
41°F to95°F / 5°C to35°C
Nonoperating Temperature
-4°F to140°F / -20°C to60°C
The Evo Notebook N400c 4-cell internal main Lithium-Ion battery provides over two hours of battery life; over four hours achieved using optional external battery.
NOTE: Actual results may vary with product model, configuration, and individual usage. Compaq results of 2:31 (hr:min) were achieved running the eTesting Labs Inc.'s BatteryMark TM Test version 4.0.1 on an N400c with an Intel Pentium III 700 MHz CPU, 12.1-inch XGA panel, 128 MB RAM, 20 GB HDD, 4-cell Lithium-Ion battery, and combination NIC/modem. System parameters were set according to Ziff Davis recommendations: panel brightness 50%, hard drive standby and video idle time 3 minutes, and Intel SpeedStep™ battery optimized mode.
NOTE: Actual results may vary with product model, configuration, and individual usage. Compaq results of 2:16 (hr:min) were achieved running the eTesting Labs Inc.'s BatteryMark TM Test version 4.0.1 on an N400c with an Intel Pentium III 850 MHz CPU, 12.1-inch XGA panel, 128 MB RAM, 20 GB HDD, 4-cell Lithium-Ion battery, and combination NIC/modem. System parameters were set according to Ziff Davis recommendations: panel brightness 50%, hard drive standby and video idle time 3 minutes, Intel SpeedStep™ battery optimized mode and battery conservation mode set to high.
NOTE: These tests were performed without independent verification by eTesting Labs Inc. eTesting Labs Inc. makes no representations or warranties as to the result of the test. BatteryMark is a trademark of Ziff Davis Publishing Holdings Inc. and affiliate of eTesting Labs Inc. in the U.S. and other countries.
Country: Flag Vietnam
