HP Compaq Business Notebook nx5000 - Installing the Display
Overview
  1. Disconnect the wireless antenna cables from the Mini PCI communications board.
  2. Remove the following components:
    • Keyboard
    • Memory shield
    • Switch cover
    • Keyboard plate
    • Fan assembly
    • Heat sink
  3. Disconnect the display cable (1) and microphone cable (2) from the system board.
  4. Remove the left and right wireless antenna cables (3) from the three clips in the top cover.
  5. Remove the left and right wireless antenna cables from the hole (4) in the system board.
  6. Close the notebook.
  7. Turn the notebook upside down, with the rear panel facing you.
  8. Remove the following screws:
    • Two screws (1) from the rear panel
    • Two screws (2) from the bottom of the notebook
  9. Turn the notebook right-side up, with the front facing you.
  10. Open the notebook until the display assembly is in an upright position.
  11. Lift the display assembly straight up (1) to remove it.
  12. If necessary, remove the left 2 and right (2) display hinge covers from the display assembly.
  13. Reverse the above procedure to install the display assembly.
