Printer Specifications for HP PSC 1400 All-in-One Printer Series
HP PSC 1400 series product models
  • HP PSC 1401
  • HP PSC 1402
  • HP PSC 1403
  • HP PSC 1408
  • HP PSC 1410
  • HP PSC 1410v
  • HP PSC 1410xi
  • HP PSC 1415
  • HP PSC 1417
Some models are not available in every region/country.
Minimum system requirements - Windows
Express installation
Windows 98, 98 SE, Me, 2000 Professional Service Pack 3 or higher, or XP
XP Media and Tablet editions are also supported.
Does not support Windows 95, 3.1, NT® 4.0, DOS, 2003 Server, or 64-bit.
Intel Pentium II, Celeron, or compatible processor
128 MB RAM
395 MB available hard disk space for software installation (including Japanese language operating systems. Express installation does NOT install the Hagaki software.)
Full-color scanning requires an additional 50 MB hard disk space
Available USB port
CD-ROM drive
SVGA 800 x 600 monitor with 16-bit color depth
Microsoft Internet Explorer 5.01 Service Pack 2 or higher
Full installation
128 MB RAM
795 MB available hard disk space for software installation (1.1 GB required on Japanese language operating systems. Full installation installs the Hagaki software.)
CD-ROM drive
Recommended
  • Intel Pentium III or higher processor
  • 256 MB RAM
  • SVGA 1024 x 768 display resolution with 24-bit color for 131x series
  • Internet access
  • Sound card
  • Adobe Acrobat 5.0 or later
Minimum system requirements - Macintosh
Mac OS 10.4 or later, Mac OS 10.3 or later, Mac OS 10.2.3 or later (Mac OS 10.2.6 or later recommended)
Does not support Mac OS 9, 10.1.5 or earlier, 10.2, 10.2.1, or 10.2.2
Not supported in the Classic Environment
G3 processor (G4 or higher recommended)
128 MB RAM (256 MB or greater recommended)
400 MB free hard drive space for software installation
HP memories disc creator software requires CD-writer and 700 MB of additional hard drive space
Available USB port
CD-ROM drive
800 x 600 display resolution with 16-bit color depth
Any web browser
Quicktime 5.0 or later
Printing specifications
  • Method: Drop-on-demand thermal inkjet
  • Language: LIDIL (lightweight imaging device interface language)
  • Print speeds vary by model and according to the complexity of the document
  • Up to 4800 x 1200 optimized dpi color with 1200 input dpi
Mode
Black/Color
Resolution (dpi)
Speed (ppm)
Maximum dpi
Black
4800 x 1200 rendered optimized dpi
0.12
Color
4800 x 1200 optimized dpi*
0.12
Best
Black
1200 x 1200
0.92
Color
1200 x 1200 up to 4800 dpi optimized
0.92
Normal
Black
600 x 600
7
Color
600 x 600
2.88
Fast Normal
Black
600 x 600
7
Color
600 x 600
4.69
Fast Draft
Black
300 x 300
18
Color
300 x 300
14
* Up to 4800 x 1200 optimized dpi color printing on premium photo papers, 1200 x 1200 input dpi.
Print cartridges or Ink cartridges
The following print cartridges are compatible with this product:
  • HP 21
  • HP 22
Duty cycle
5,000 printed pages per month maximum
I/O interface
USB (USB 1.1 and 2.0 compatible)
HP recommends using a USB cable less than or equal to 3m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Paper specifications
Paper tray capacity
Type
Paper weight
Input tray capacity*
Output tray capacity**
Plain paper
70 to 90 gsm (20 to 24 pound)
100
50
Legal paper
100
50
Cards
200 gsm (110 pound index)
20
10
Envelopes
75 to 90 gsm (20 to 24 pound)
10
10
Transparency film
N/A
20
15 or less
Labels
N/A
20
10
4 x 6 inch (10 x 15 cm) photo paper
236 gsm (145 pound)
20
8.5 x 11 inch (216 x 279 mm) photo paper
N/A
20
10
* Maximum capacity.
** Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Paper sizes
Type
Size
Paper
Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
A5: 148 x 210 mm
Executive: 184 x 267 mm (7.25 x 10.5 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes
U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 99 x 226 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency films
A4: 210 x 297 mm
Photo paper
102 x 152 mm (4 x 6 inches)
Cards
76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
127 x 178 mm (5 x 7 inches)
A6: 105 x 149 mm
Hagaki card: 100 x 148 mm (3.94 x 5.83 inches)
Labels
A4: 210 x 297 mm
Custom
76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches)
Print margin specifications
Paper size
Top (leading edge)
Bottom (trailing edge)*
US Letter, Legal, and Executive
1.5 mm (0.06 inches)
12.7 mm (.5 inch)
ISO A4
ISO A5
JIS B5
1.8 mm (.07 inch)
12.7 mm (.5 inch)
Envelopes
3.2 mm (0.13 inches)
3.2 mm (.13 inch)
Cards
1.8 mm (.07 inch)
11.7 mm (.46 inch)
* This margin is not compatible with the HP All-in-One; however, the total writing area is compatible. The writing area is offset from center by 5.4 mm (0.21 inches), which causes asymmetric top and bottom margins.
Scanning specifications
  • Image editor included
  • Integrated OCR software automatically converts scanned text to editable text
  • Scan speeds vary according to the complexity of the document
  • Twain-compliant interface
  • Resolution: up to 600 x 2400 dpi optical; 19200 dpi enhanced by software (maximum resolution is limited by available computer memory, disk space, and other system factors)
  • Color: 36-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Copying specifications
  • Fit to page
  • Digital image processing
  • Up to 9 copies from original (varies by model)
  • Copy speeds vary by model and according to the complexity of the document
  • Up to 18 copies per minute black; 14 copies per minute color (varies by model)
Mode
Black/Color
Speed (ppm)
Print resolution (dpi)
Scan resolution (dpi)*
Best
Black
up to 0.8
600 x 600
600 x 2400
Color
up to 0.8
1200 x 1200**
600 x 2400
Fast
Black
up to 23
300 x 1200
600 x 1200
Color
up to 18
600 x 300
600 x 1200
* Maximum at 400% scaling
** On photo paper
Physical specifications
Dimension
Measure
Height
16.97 cm (7.0 inches)
Width
44 cm (16.8 inches)
Depth
25.9 cm (10.2 inches)
4.5 kg (10 pounds)
Power specifications
  • Power consumption: 80 W maximum
  • Input voltage: AC 100 to 240 volts - 1 A 50-60 Hz, grounded
  • Output voltage: DC 32 volts === 940 mA, 16 volts === 625 mA
Environmental specifications
  • Recommended operating temperature range: 15 to 32 degrees Celsius (59 to 90 degrees Fahrenheit)
  • Allowable operating temperature range: 5 to 40 degrees Celsius (41 to 104 degrees Fahrenheit)
  • Humidity: 15 to 85 percent RH non-condensing
  • Non-operating (storage) temperature range: -40 to 60 degrees Celsius (minus 40 to 140 degrees Fahrenheit)
  • In the presence of high electromagnetic fields it is possible the output from the HP PSC might be slightly distorted.
  • HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
