HP Notebook PCs - Solve Setup and Internet Connection Issues on a Wireless Network with XP
This document pertains to HP Notebook PCs with Windows XP.
If the computer is not using the XP operating system, see
Read this document if you are having trouble setting up a connection to a home wireless network or public Wi-Fi network. This document assumes that you have configured all the required wireless components, and that you have successfully connected to your home wireless network before. However, there now is a problem connecting a computer to the wireless network.
Detailed instructions on how to troubleshoot a wireless connection problem
The following sections of this document provide detailed explanations of the troubleshooting process and corrective actions. Perform these actions in the sequence listed in the chart shown above.
Verify the AC adapter and wireless device power settings
If your wireless connection suddenly stops working when your notebook is operating on battery power, you may want to disable the following power saver options.
