HP Compaq 4200 series PCs - System Views
Front View
  1. Infrared port
  2. Bluetooth module
  3. Display release button
Top View
  1. Function keys
  2. fn key
  3. Windows logo key
  4. Windows applications key
  5. Embedded numeric keypad
LEDs
  1. Mute LED (amber)
  2. Caps lock LED (green)
  3. HDD/ODD activity
  4. LED (green)
  5. Battery LED (green/amber)
  6. Power/Standby LED (green)
  7. Wireless LED (blue)
  8. Num lock LED (green)
Buttons
  1. Presentation Mode
  2. Mute
  3. Volume down
  4. Volume up
Wireless antennae
Antennae (2)
Note: The antennae are not visible from the outside of the PC. For optimal transmission, keep the areas immediately around the antennae free from obstructions
Pen-activated buttons (tc4200 only)
  1. Tablet PC Input Panel Launch button
  2. Rotate button
  3. Q Menu button
Display components (tc4200 only)
  1. Pen holder
  2. Pen eject button
  3. Rotating hinge
  4. Jog dial
  5. Windows Security button
Pointing devices
  1. Pointing stick
  2. Left pointing stick button
  3. TouchPad
  4. Left TouchPad button
  5. Right TouchPad button
  6. TouchPad scroll zone
  7. Right pointing stick button
Pen (tc4200 only)
  1. Pen tip
  2. Pen button
  3. Pen tether eyelet
  4. Pen eraser
Left side view
  1. Security cable slot
  2. Vent
  3. Wireless button
  4. USB port
  5. InfoCenter button
  6. Power switch
  7. Speaker
Right side view
  1. Audio-out (headphone) jack
  2. Audio-in (microphone) jack
  3. USB port (this is a powered USB port that can be used without external power and supports connection to a MultiBay II)
  4. PC Card eject button
  5. PC card slot
  6. SD card slot
Rear view
  1. USB port
  2. RJ-11 modem jack
  3. RJ-45 network jack
  4. Power connector
  5. External monitor port
  6. S-Video-out jack
Bottom view
  1. Docking connector
  2. Expansion memory module compartment
  3. Vents (3)
  4. Primary battery bay
  5. Primary battery release latch
  6. Hard drive bay
  7. Travel battery connector
