    Fix HP Printer issue on macOS
HP Designjet 4000 Printer Series - Navigating the Front Panel Menus
There are four main menu options on the printers front panel:
  • Ink menu
  • Paper menu
  • Jobs menu
  • Setup menu
    Figure : Front panel
  1. Display area - where information, icons, and menus are displayed.
  2. Power key - turns the printer on and off. If the printer is in sleep mode, this key will wake it up.
  3. Power light - is off when the printer is off; amber when the printer is in sleep mode; green when the printer is on; green and flashing when the printer is in transition between off and on.
  4. Form Feed and Cut key - normally ejects the sheet (if a sheet is loaded) or advances and cuts the roll (if a roll is loaded). However, if the printer is waiting for more pages to be nested, this key cancels the waiting time and prints the available pages immediately.
  5. Reset key - restarts the printer (as if it were switched off and switched on again). You will need an implement with a narrow tip to operate the Reset key.
  6. Cancel key - cancels the current operation. It is often used to stop printing the current print job.
  7. Status light - is off when the printer is not ready to print: it may be off, or in sleep mode. It is green when the printer is ready and idle; green and flashing when the printer is busy; amber when a serious internal error has occurred; amber and flashing when awaiting human attention.
  8. Up key - moves to the previous item in a list, or increases a numerical value.
  9. Select key - selects the item that is currently highlighted.
  10. Back key - goes back to the previous menu. If you press it repeatedly, or hold it down, you will soon return to the main menu.
  11. Down key - moves to the next item in a list, or decreases a numerical value.
A few tricks:
  • When a selection is made, the printer does not automatically return to the upper or main menu immediately. It will however, automatically go to the main menu if not used for about one minute.
  • If no tool is available to press the Reset button, use the main power switch located on the back of the printer (same result).
A very fine point, just over 0.5cm long, is required to activate the reset button.
Use the arrow keys on the printers front panel to scroll through the menus and submenus. When the appropriate menu/submenu option is highlighted, press the Select key on the front panel to access the option, change a setting or run an internal test.
Ink menu naviagation
Below is a graphical outline of the Ink menu navigation.
Figure : Ink menu
Below is a list of the Ink submenu's and the options available in each.
  • Printheads - recover printheads, align printheads, replace printheads, calibrate color and printhead information.
  • Ink cartridges - replace ink cartridges and to retrieve ink cartridge information.
  • Drying options - set drying time options
Jobs menu naviagation
Below is a graphical outline of the Jobs menu navigation.
Figure : Jobs menu
Below is a list of the Jobs submenu's and the options available in each.
  • Reprint last job - reprint the last print job
  • Queue management - manage print jobs that are in the queue
  • Queue - turn the printers queue on and off
  • When to start printing - tells the printer when to start printing a file
  • Nest options - turn nesting on or off, and set nesting wait times
  • Max. number of printed jobs - the Max number of jobs that will be stored in the queue (can be set from 0 to 30)
  • Job recovery options - put jobs on hold or cancel jobs
Paper menu naviagation
Below is a graphical outline of the Paper menu navigation.
Figure : Paper menu
Below is a list of the Paper submenu's and the options available in each.
  • Unload paper now - unloads media that is currently loaded
  • Roll - select paper type, check roll information and instructions on how to load the spindle
  • Sheet - provides information on sheet media that is loaded (if loaded)
  • Paper handling options - cutter on or off
  • Paper advance calibration - provides paper advance calibrations for drawing/text and Images
Printer Setup menu naviagation
Below is a graphical outline of the Printer Setup menu navigation.
There are several submenu's in the Setup menu, all of which are graphically displayed below. The options for each of these submenu's are detailed below each of the graphics.
Figure : Information menu
Below is a list of the Information sub-menu and the options available in each.
  • Show printer information - provides information about the printer (i.e. serial number, memory, firmware version)
  • Show log - provides internal printer logs for system errors, system warnings, printheads and ink cartridges
  • Internal prints - access to perform internal prints (i.e. Print demo, Print usage report, Print PS font list)
Figure : Configuration menu
Below is a list of the Configuration sub-menu, and the options available in each (for graphic directly above).
  • Sleep mode wait time - set the printers sleep mode wait time (default, 60 min)
  • Auto printhead alignment - turn the automatic printhead alignment on or off (default, On)
  • Color calibration - turn the color calibration on or off (default, On)
  • Printhead monitoring - change printhead monitoring settings (default, Optimized)
  • Language - change the display language (default, English)
  • Buzzer - turn buzzer on or off (default, On)
Figure : Configuration menu continued
Below is a list of the Configuration sub-menus and the options available in each (for graphic directly above).
  • Contrast - adjust the printers display contrast (default, 50%)
  • Unit selection - change the printers measurment type (default, metric)
  • Altitude - change the printers altitude setting (default, 0-1000 Meters)
  • Reset EWS password - change the Embedded Web Server password
  • Allow EWS - turn EWS on or off (default, On)
  • Allow SNMP - turn SNMP on or off (default, On)
  • Restore factory settings - restore the printer to original factory settings
Figure : Printing defaults menu
Below is a list of the Printing defaults sub-menus and the options available in each (for graphic directly above).
  • Graphic language - change the printers graphic language setting (default, Automatic)
  • Image quality - select print quality settings (default, Normal), optimize printing for drawings/test or for images (default, Drawings/test), and turn Maximum detail on or off (default, Off)
Figure : Printing defaults menu (continued)
Below is a list of the Printing defaults sub-menu for paper options and the selections available in each (for graphic directly above).
Paper options:
  • Size - select paper sizes (default, Automatic)
  • Save roll paper - select Save roll paper options (default, Off)
  • Scale - select Scale options (default, 100%)
  • Rotate - select Rotate options (default, 0 degrees)
  • Margins - select Margin settings (default, Normal)
  • Mirror - select to print mirror image (default, Off)
Below is a list of the Printing defaults sub-menu for HP-GL/2 options and the selections available in each (for graphic directly above).
  • Palette - change the internal printer palette (default, Software)
  • Define palette - choose from Palette A, Palette B or Factory
  • Merge - turn merge on or off (default, Off)
Below is a list of the Printing defaults sub-menu for Color options and the selections available in each (for graphic directly above).
Figure : I/O setup menu
Below is a list of the Printing defaults sub-menu for I/O options and the selections available in each (for graphic directly above).
  • I/O timeout - change I/O timeout setting
  • IP interface selection - choose depending on the network connection type
  • Fast Ethernet - select Fast Ethernet options
  • Gigabit Ethernet - Installed, IP enabled, Printing enabled, Show configuration, Modify configuration, Restore factory settings
Figure : I/O setup continued and Accessories menu
Below is a list of the I/O options sub-menu and the selections available in each (for graphic directly above).
  • 1394 FireWire - displays FireWire information
  • USB - displays USB information
  • Jetdirect EIO - displays Jetdirect EIO information
Below is a list of the Accessories options sub-menu and the selections available in each (for graphic directly above).
  • Other accessories - provides notification of other accessories that may be installed
