HP Flat Panel Monitor L1755 - Specifications
Panel specifications
Panel
Panel type
Active matrix TFT (thin film transistor); anti-glare/anti-static coatings
43.2 cm (17 in) maximum viewable maximum viewable
Screen opening (W x H)
33.9 x 27.2cm (13.4 x 10.7 in)
Viewing angle (typical)
176 degrees horizontal/176 degrees vertical (10:1 minimum contrast ratio)
Brightness (typical)
Up to 250 nits (cd/m2)
Contrast ratio (typical)
Up to 1000:1 (typical)
Response rate (typical)
25 ms (typical, rise + fall)
Pixel pitch
0.264 mm
Color depth support
16.7 million colors
Physical specifications
Dimensions (H x W x D)
Panel only without stand
  • 30.1 x 40.9 x 7.3 cm (11.8 x 14.4 x 2.9 in)
Unpacked with stand
  • With stand raised: 42.2 x 36.5 x 21.1 cm (21.2 x 14.4 x 8.3 in)
  • With stand lowered: 40.9 x 36.5 x 21.1 cm (16.1 x 14.4 x 8.3 in)
Base area (footprint)
  • 21.1 x 30.9 cm (8.3 x 12.2 in)
Packed
  • 9.2 kg (20.2 lb)
Unpacked with stand
  • 6.7 kg (14.7 lb)
Panel only (without stand)
  • 3.7 kg (8.1 lb)
Tilt range
-5 to + 35 degrees
Swivel range
+ and - 50 degrees horizontal swivel
Height adjustable
Yes (13 cm/5.1 in adjustment range)
Pivot rotation
Yes, 90 degrees
Base
Ships detached and is removable after installation
Environmental specifications
Temperature
Operating
  • 5 to 35 degrees C (41 to 95 degrees F)
Non-operating
  • -20 to 60 degrees C (-4 to 140 degrees F)
Humidity
Operating
  • 20 to 80% non-condensing
Non-operating
  • 5 to 95%
Altitude
Operating
  • 0 to 4,000 m (0 to 13,000 ft)
Non-operating
  • 0 to 12,192 m (0 to 40,000 ft)
Electrical specifications
Power
Internal power supply
Auto-ranging, 90 to 265 VAC
Input power
100 to 240 VAC
Nominal current
1.5 A maximum
Frequency
50 to 60 Hz
Average
33 W when displaying standard office software
Typical power consumption
< 40 W
Maximum
< 60 W
Power saving
< 2 W
Off mode
0 W (when master power switch is in the off position)
Power cable length
1.8 m (70 in); non-captive
On-screen display (OSD) controls
OSD controls
Buttons or switches
  • Power on/off
  • 3-button OSD
  • second level OSD buttons include dual-input switch, dedicated auto adjust switch
Languages
English, French, German, Spanish, Italian
User controls
  • Size and positioning
  • Brightness
  • Contrast
  • Clock and clock phase
  • Selectable color temperature
  • Serial number display
  • Mode display
  • Sleeper timer
  • Input selection
  • Factory reset
  • Individual color contrast
  • Full screen resolution
Signal interface/performance specifications
Horizontal frequency
30 to 82 kHz
Vertical frequency
56 to 75 Hz
Native resolution
Analog
  • 1280 x 1024 @ 75 Hz
Digital
  • 1280 x 1024 @ 60 Hz
Maximum resolution
Analog
Digital
Preset VESA graphic (non-interlaced)
640 x 480 @ 60 Hz, 72 Hz, 75 Hz
720 x 400 @ 70 Hz
800 x 600 @ 60 Hz, 72 Hz, 75 Hz
1024 x 768 @ 60 Hz, 70 Hz, 75 Hz
1280 x 1024 @ 60 Hz, 75 Hz
Preset MAC mode
832 x 624 @ 75 Hz
1152 x 870 @75 Hz
Preset VGA mode
SUN mode
1152 x 900 @ 76 Hz
Fail safe mode
Yes (limits out of range signal messages)
Maximum pixel clock speed
140 MHz
User programmable modes
Yes, 15
Anti-glare
Yes
Anti-static
Yes
Asset control
Yes (accessible on HP Compaq Business Desktops featuring Intelligent Manageability)
Default color temperature
Yes (6500k, 9300k, SRGB, Custom User)
Video input specifications
Video input
Plug and play
Yes (supports VESA DDC2B; PC2001 compliant)
Self-powered USB 2.0 hub
One upstream, four downstream ports (cable included)
Input signal
Two connectors
  • One 15-pin mini D-sub VGA
  • One DVI-I (VGA analog and digital input)
Input impedance
75 ohms + and - 10%
Sync input
Separate sync (HSYNC/VSYNC); composite sync, sync on Green (activated through on-screen display)
Video cable
  • VGA to VGA
  • DVI-I to VGA
  • DVI-D to DVI-D
Video cable length
2.0 m (78 in)
Factory preset display modes
Preset
Pixel Format
Horizontal Freq (KHz)
Horizontal Polarity
Vertical Freq (Hz)
Vertical Polarity
Pixel Clock (MHz)
Source
1
640 x 480
31.469
59.940
25.175
VGA
2
640 x 480
37.861
72.809
31.500
VESA
3
640 x 480
37.500
75.000
31.500
VESA
4
720 x 400
31.469
70.087
28.322
VGA
5
800 x 600
31.469
60.317
40.000
VESA
6
800 x 600
48.077
72.188
50.000
VESA
7
800 x 600
46.875
75.000
49.500
VESA
8
832 x 624
49.726
+ and -
74.551
+ and -
57.284
MAC
9
1024 x 768
48.363
60.004
65.000
VESA
10
1024 x 768
56.476
70.069
75.000
VESA
11
1024 x 768
60.023
75.029
78.750
VESA
12
1152 x 870
68.68
75.06
10.000
Mac
13
1152 x 900
71.71
76.05
105.561
Sun
14
1280 x 1024
63.98
60.02
108.000
VESA
1280 x 1024
79.97
75.02
135.000
VESA
