    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Photosmart 325, 335, 375, and 385 - Installing Print Cartridges
  1. Open the print cartridge access door, then wait until the print cartridge carriage is idle and silent.
    Figure : Opening the print cartridge access door
  2. Press down on the end of the cartridge to release it.
    Figure : Releasing cartridge
  3. If you are installing a new print cartridge, remove the protective tape.
    Figure : Removing the protective tape
  4. Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
    Avoid touching the nozzles or contacts!
    1. Contacts
    2. Nozzles
    Figure : Installing the cartridge
  5. Press the cartridge into the carriage until it snaps into place.
  6. Close the print cartridge access door.
