HP iPAQ Pocket PC hx4700 Series - How Do I Protect My Pocket PC from Screen Damage or Cracking?
The screen on your Pocket PC is made of glass and can be damaged or broken by drops, impacts, or pressure.
HP is not responsible for damage that occurs as a result of your failure to follow the instructions that came with the HP branded product. Refer to the warranty document included with your Pocket PC for more information.
You should observe the following guidelines to protect the screen on your iPAQ Pocket PC from damage:
  • Do not sit on your Pocket PC.
  • When transporting your Pocket PC in a purse, pocket, briefcase, etc., ensure the device does not get compressed, bent, dropped, or hit.
  • When not in use, close the flip cover on your Pocket PC and store it in a case. You can select from a wide variety of case options at www.hp.com/go/ipaqaccessories.
  • Do not place anything on top of your Pocket PC.
  • Do not bang your Pocket PC against hard objects.
  • Never use any device other than the stylus that comes with the Pocket PC or an approved replacement to tap or write on the screen. If you lose or break your stylus, you can order extras at www.hp.com/go/ipaqaccessories.
  • Clean your Pocket PC by wiping the screen and the exterior with a soft, damp cloth lightly moistened only with water.
To reduce the risk of damage to the internal components, do not spray liquid directly on the screen, or allow excess liquid to drip inside your Pocket PC. Using soap or other cleaning products on the screen may discolor the finish and damage it.
Country: Flag Vietnam
