    Windows 11 Upgrade Guide
HP Designjet EFI Designer Edition RIP - Processing Incomplete
Issue:
The EFI Designer Edition RIP is displaying the message processing incomplete.
The error messages displayed in the program window are preceded by the word "input," "color," "print," or "port" to indicate at which stage of processing the problem occurred.
Solution
Check your job file. If the problem persists, try printing a different job to ascertain if the problem is repeated with other files. If necessary, contact EFI Support at http://www.efi.com/support.
Cause
The job could not be successfully processed. There may be a problem with the file.
