HP Designjet EFI Designer Edition RIP - Cannot Process Job
Issue:
The EFI Designer edition RIP is displaying the error cannot process job.
The error messages displayed in the program window are preceded by the word “input”, “color”, “print” or “port” to indicate at which stage of processing the problem occurred.
Solution
Restart the EFI Designer Edition RIP.
Cause
The system may be overloaded.
