HP iPAQ Pocket PC h6300 Series - How do I Find Out What's on my CD?
The Companion CD is located in the box and contains:
  • Microsoft ActiveSync 3.7.1
  • Microsoft Outlook 2002
  • HP iPAQ Pocket PC h6300 Series User’s Guide
  • How Do I...? (this document)
  • Know Your Options (Accessories Information)
  • Important Safety Information
Figure : HP iPAQ Pocket PC Companion CD
All of the software and documents are designed to be installed on your personal computer to enhance your ability to use your iPAQ Pocket PC to its fullest potential. The CD also contains Microsoft add-on software applications and Pocket PC enhancements that can be installed directly onto your Pocket PC for use on the go.
It is recommended that you save the original packaging for the CD because the Microsoft product key for installing Microsoft Outlook is located on the sticker on the CD packaging. You will need that information if you ever need to reinstall Outlook on your personal computer.
Country: Flag Vietnam
