    Looking for Site Help?
HP mp2200 and vp6200 Series Digital Projectors - Maintaining the Projector
Your projector requires little maintenance other than cleaning. Never remove any parts of the projector other than the lamp. Contact HP if other parts need replacement.
Cleaning the projector
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface. Dust or dirt on the lens will affect picture quality.
  • Remove dust and debris using a canister of compressed air (canned air).
  • If there are smears or dust that cannot be removed using compressed air, use commercial lens-cleaning paper or a soft cloth that is slightly dampened with lens cleaner to gently wipe the lens surface. Avoid using anything that will scratch the lens.
The case of the projector should be cleaned if it is dusty or dirty.
  • Before cleaning the case, turn the projector off and disconnect the power cord.
  • To remove dirt or dust, wipe the case with a soft, dry, lint-free cloth.
  • To remove stubborn dirt or stains, moisten a soft cloth with water and a neutral detergent like dish soap.
Never use wax, alcohol, benzene, thinner or other chemical detergents. These can damage the projector.
Storing and transporting the projector
If you need to store the projector for an extended time, or will be transporting it, follow the instructions listed below:
  • Verify that the temperature and humidity of the storage area are within the recommended range for the projector.
    Temperature
    -25 to 55 degrees C (-4 to 131 degrees F)
    Humidity
    Less than 80% RH, non-condensing
    Altitude
    Less than 12,000 meters (40,000 feet)
  • Retract the adjuster feet.
  • Remove the batteries from the remote control.
  • Pack the projector in its original packing, or equivalent. The projector should be padded on all sides.
  • Obtain a carrying case to protect the projector while it is being transported.
Replacing the battery in the remote control
  • Replace the battery in the remote control.
    1. Use a ballpoint pen to hold the battery latch toward the center, then pull out the battery holder.
        Figure : Replacing the battery in the remote control
      1. Pulling out the battery holder
      2. Inserting the new battery
      3. Pushing the battery holder into place
    2. Insert the new battery in the holder.
    3. Push the holder into the remote control.
HP vp6200 series
Follow the steps below to replace the battery in the remote control:
  1. On the back of the remote control, use a ballpoint pen to push and hold the battery latch toward the center of the remote, and then pull out the battery holder.
    1. Releasing the battery holder latch
    2. Pulling out the battery holder
  2. Remove the old battery from the battery holder.
    Figure : Removing the old battery
  3. Insert the new battery in the holder.
  4. Push the holder into the remote control.
  warning:
Avoid excessive heat and humidity. There may be danger of an explosion if the battery is incorrectly replaced. Replace only with the same or equivalent type recommended by the battery manufacturer.
When discarding old batteries, contact your local waste-disposal provider regarding local restrictions on the disposal or recycling of batteries.
Country: Flag Vietnam
