HP Designjet 10ps Printer - Printer Installation Couldn't be Found Message Appears after Installing EFI Designer Edition 4.0 for HP
Issue:
The message Printer Installation Couldn't be Found appears after installing the EFI Designer Edition 4.0 for HP.
Solution
Follow the steps below:
  1. Click here to download the missing PPD (hpdj10.sit) from the following Web site at http://www.bestcolor.com/download/fixes/hpdj10.sit.hqx.
  2. Select Save.
    Save the WinZip file on your desktop or another preferred folder on the computer.
  3. Un-zip the file and copy the un-zipped file to the PPD folder in the Best Designer Edition Applications folder
Cause
A missing PPD file (hpdj10.sit) has not been installed and is generating this error message.
