HP Workstation b2600 - Replacing the Liquid Crystal Display (LCD) Module
To remove the liquid crystal display, follow this procedure:
  1. Remove the front bezel and top cover.
  2. Disconnect the LCD control cable.
      Figure : Disconnecting the LCD control cable
    1. LCD connector
    2. LCD control cable
  3. Press inward on the right side of the LCD's plastic retainer with a screwdriver and pull outward on this same side. See Figure 2. This will remove the LCD module.
      Figure : Removing the LCD module
    1. LCD module
Replacing the liquid crystal display (LCD) module
To replace the liquid crystal display, follow this procedure:
  1. Remove the front bezel if you have not already done so. Otherwise, skip this step.
  2. Replace the LCD module by inserting the left-side and right-side retainer clips in their slots and pressing inward to snap them in place.
    Figure : Replacing the LCD module
    1. Two left-side retainer clips
    2. Right-side retainer clip
  3. Connect the LCD control cable connector to the LCD connector.
      Figure : Connecting the LCD control cable connector
    1. LCD connector
    2. LCD control cable connector
    3. LCD
  4. Replace the front bezel and top cover.
  5. Connect and turn on the power to your system.
  6. Determine that your LCD module replacement was successful by looking at the LCD and noticing if the LCD lights up and the heart shaped activity indicator is blinking. If the LCD does not light up and the heart shaped activity indicator is not blinking, repeat this procedure. If your LCD continues to not light up and the heart shaped activity indicator is not blinking, contact your HP Support Representative.
Country: Flag Vietnam
