HP 3770 Series Digital Flatbed Scanner - Overview, Accessories, and Front Panel Buttons
Overview of the HP software
If HP Windows software from CD 2 is installed, the software names in the documentation differ as follows from what was installed:
1) The software is named HP Photo & Imaging instead of HP Image Zone.
2) The picture management software is called HP Photo & Imaging Gallery instead of HP Image Zone. There may be other terminology differences between the installed software and the documentation.
Figure : Scanner with built-in transparent materials adapter (TMA)
  • The HP Director provides easy access to the software applications, default settings, status, and onscreen help for HP devices. Use the HP Director software to scan various types of originals (pictures, slides, negatives, and documents), make copies, view and print images, go to the HP Shopping Web site, and update HP software.
  • The HP Image Zone provides tools for managing still photos, scanned images, and video clips. Easily edit and print images, use the images in various projects, and share the images with family and friends.
  • Use the HP Scanning software to scan items such as pictures, slides, negatives, and documents, and then save them or send them to a software application or file. The software gives the option of previewing and adjusting images before the final scan takes place. Use the software to configure scan settings.
  • The HP Copy software sends scanned images directly to the printer.
For more information on the HP software, see the HP Director onscreen help. To access the onscreen help in the HP Director, do the following:
  1. Do one of the following:
    • On the Windows desktop, double-click the HP Director icon.
    • In the system tray at the far right of the Windows taskbar, double-click the HP Digital Imaging Monitor icon.
    • On the taskbar, click Start, point to Programs or All Programs, point to HP, and then click Director.
  2. If more than one HP device is installed, click one in the Select Device list. The HP Director displays only the buttons that are appropriate for the selected device.
  3. Click the Help button.
Scanner buttons and accessories
Feature
Scan
Scans pictures and documents from the scanner glass, and scans slides and negatives from the TMA.
Copy
Scans the item from the scanner glass to a printer to make copies.
HP Instant Share
Scans the item, send it in an e-mail, create an album on the HP Photo Web site, or order high-quality prints. (Not all services are available in all locations.)
Transparent materials adapter (TMA)
Use the transparent materials adapter (TMA) to scan 35 mm slides or negatives. For more information about the TMA, see Scan slides and negatives.
