HP Compaq Business Notebook nc8000 Series - Hardware Specifications and Product Features
Physical specifications
Attribute
Measure
Height
4.1 centimeters (1.61 inches)
Width
32.6 centimeters (12.84 inches)
Depth
27.5 centimeters (10.83 inches)
Weight (with main battery pack and MultiBay weight saver)
2.95 kilograms (6.50 pounds)
Stand-alone power requirements
Attribute
Requirement
Nominal operating voltage (Li-Ion)
14.4 Volts, direct current
Maximum operating power
60.0 Watts
Peak operating power
65.0 Watts
Temperature
Attribute
Measure
Operating
10 to 35 degrees Celsius (50 to 95 degrees Fahrenheit)
Nonoperating
-20 to 60 degrees Celsius (4 to 140 degrees Fahrenheit)
Applicable product safety standards specify thermal limits for plastic surfaces. The notebook operates well within this range of temperatures.
Relative humidity (noncondensing)
Attribute
Measure
Operating
10 to 90 percent
Nonoperating
5 to 90 percent, 38.7 degrees Celsius (101.6 degrees Fahrenheit) maximum wet bulb temperature
Altitude
Attribute
Measure
Operating (14.7 to 10.1 psia)
0 to 3,048 meters (0 to 10,000 feet)
Nonoperating (14.7 to 4.4 psia)
0 to 9,144 meters (0 to 30,000 feet)
Shock
Attribute
Measure
Operating
40 G, 2 ms, half-sine
Nonoperating
240 G, 2 ms, half-sine
Vibration
Attribute
Measure
Operating
0.5 G zero-to-peak, 10 to 500 Hz, 0.5 oct/min sweep rate
Nonoperating
1.0 G zero-to-peak, 10 to 500 Hz, 0.5 oct/min sweep rate
Features
  • Mobile Intel Pentium 4 Processor-M 1.7-, 1.6-, and 1.4-GHz processors, all with 1024-KB L2 cache and 400-MHz processor side bus, varying by notebook model
  • 15.1-inch UXGA (1600×1200), SXGA+ (1400×1050), or XGA (1024×768) TFT display with over 16.7 million colors, varying by notebook model
  • ATI MOBILITY RADEON 9600 Pro graphics controller with 128 or 64 MB of video memory, varying by notebook model
  • 80-, 60-, or 40-GB high-capacity hard drive, varying by notebook model
  • 256-MB DDR Synchronous DRAM (SDRAM) at 333 MHz, expandable to 2.0-GB
  • Microsoft Windows 2000 or XP Pro, varying by notebook model
  • Full-size Windows 98 keyboard with integrated numeric keypad
  • Dual point (TouchPad and pointing stick) pointing device, with TouchPad on/off button and light
  • Integrated Secure Digital (SD) flash media slot
  • Integrated 10/100/1000BASE-T Ethernet local area network (LAN) NIC with RJ-45 connector
  • Integrated wireless support for Bluetooth LAN and Mini PCI 802.11a/b/g LAN devices
  • Support for fixed optical drive and MultiBay device
  • Support for two Type II/Type III PC Card slots with support for both 32-bit (CardBus) and 16-bit PC Cards
  • External 65-watt AC adapter with power cord
  • 8-cell Li-Ion battery pack
  • HP PremierSound audio
  • Support for the following optical drives:
    • 24X Max DVD/CD-RW combination drive
    • 8X Max DVD+RW drive
    • 8X Max DVD-ROM drive
    • 24X Max CD-ROM drive
  • Connectors:
    • SD Memory Card
    • Infrared
    • Two Type II PC Card slots
    • RJ-11 (modem)
    • RJ-45 (NIC)
    • Two Universal Serial Bus (USB) v. 2.0
    • S-Video
    • Parallel
    • Serial
    • External monitor
    • DC power
    • Docking
    • IEEE 1394 digital
    • Microphone
    • Stereo speaker/headphone
