A power-on password prevents unauthorized use of the notebook.
Once set, a power-on password must be entered each time the
notebook is turned on or restarted. A power-on password:
Does not display as it is set, entered, changed, or deleted.
Must be set and entered with the same keys. For example, a power-on password set with keyboard number keys will not be recognized if entered with keypad number keys.
Can include any combination of up to 32 letters and numbers and is not case-sensitive.
