HP Digital Sender 9100c - Missing Edit List Button When Trying to Replicate from the EWS
Issue:
The Edit List button is not visible after pressing the Replication Setup when trying to replicate using the embedded Web server.
Solution
This may be fixed by flashing the HP Digital Sender's firmware with the 5.01x update even if the sender already has this firmware image. After the HP Digital Sender reboots the EWS page should show the Edit List button.
Replications may also be performed in Enterprise Center.
Summary
Without the Edit List button you will not be able to specify destinations that will receive the replicated data. Flashing the firmware appears to fix the missing or invalid html script that is used to create this button.
