HP Digital Sender 9100c - Error Message "The DNS configuration is inconsistent, Please check it."
Issue:
After pressing the Shift, Alt and green key to enter the configuration screen on the front panel of the digital sender. A message appears "The DNS configuration is inconsistent, Please check it."
Solution
There must be a value for the IP address even if it is 0.0.0.0, this field cannot be left blank.
Summary
When not using a DNS server and the value stored in the network settings becomes corrupt or invalid a new entry is needed to correct the error, even if it is the same number typed or a null value like 0.0.0.0.
