HP Officejet 9100 All-in-One Series - Customization Utility
The customization utility creates a customized installer with pre-selected options. The customized installer can be copied on to floppy disks, CD, or it can be shared on the network.
The following steps are used to create a customized installer:
  1. Start Windows and ensure that no other Windows applications are running.
  2. Insert the Starter CD into the CD-ROM drive. The system setup wizard runs automatically. The startup page of the CD browser screen is displayed.
  3. On the CD Browser screen, click Customization Utility.
  4. The welcome screen appears. Click Next on the Welcome to the HP Officejet 9100 series Installer Customization Wizard screen.
  5. Select the Language for the Installer and then click Next.
  6. Select the Queue Name or Printer Port to which the printer is connected and then click Next.
  7. Select the Connector Type and then click Next.
  8. Select the printer Model that is to be installed from the displayed list and then click Next.
  9. Select the Features that the customized installer should install and then click Next.
  10. Select Yes, allow me to configure the drivers , if the drivers support pre-configuration. However, if desired, select No, I don’t want to configure the drivers and then click Next.
  11. Specify a Printer Name and check Default Printer to use this printer as the default printer for Windows and then click Next.
    For direct connect, the printer must be physically connected when prompted by the software installer during the installation. If the printer is not physically connected, installation will not continue and a software rollback will be initiated (removal of pre-installed files). The Add printer installation does not require a physical printer connection during the installation.
Country: Flag Vietnam
