HP bt1300, Bluetooth Wireless Printer Adapter - SPP Printing with Widcom 1.3
Installing the printer on the Laptop
  1. Double-click the Bluetooth icon on the desktop to open the Bluetooth Neighborhood utility.
    Figure : Bluetooth icon
  2. Click Search for Devices in the Bluetooth Neighborhood utility.
    Figure : Bluetooth Neighborhood
  3. Right-click the printer and select pair.
    Figure : The printer
  4. Right-click again select Connect to Bluetooth Serial Port.
    Figure : Serial Port
  5. A Serial Port Dialog box shows the printer is connected to a COM port (COM5 in this example.)
    Remember this COM Port for use later.
    Figure : Serial Port Profile
  6. Open the Add Printer Wizard by clicking Start, Settings, Printers and Faxes. Then click Next.
    Figure : Add Printer Wizard
  7. Select Local printer attached to this computer and click Next.
    Figure : Local or Network Printer
  8. Select the COM port remembered from Step 5 and click Next.
    Figure : Select the COM port
  9. Select the printer driver and click Next.
    Figure : Printer driver
  10. Choose to use the existing driver (if the printer was previously installed) and click Next.
  11. Name the printer on the Name Your Printer screen, then decide if this printer should be the default printer.
  12. Select Yes in the Print a Test Page screen, then click Next.
  13. Click Finish at the Completing the Add Printer Wizard screen.
It may also be necessary to go back to Step 5 and re-connect to the printer if it has timed-out before reaching this step.
Country: Flag Vietnam
