    Looking for Site Help?
HP iPAQ Products - Using the Stylus
This document applies to the iPaqs that comes with a touch sensitive screen and are compatible with stylus pen. The information below does not apply to iPaq 510 voice messenger series.
Your iPAQ has a stylus for selecting items and entering information. To use the stylus, press and hold the stylus release button while pulling the stylus upward out of its compartment. To replace the stylus, just insert it back into the compartment, then push it until it clicks into place.
The following actions are available with the stylus:
  • Tap - Touch the screen once with the stylus to open items and select options.
  • Drag - Hold the stylus on the screen and drag it across the screen to select text and images. Drag within a list to select multiple items.
  • Tap-and-hold - Tap and hold the stylus on an item to see a list of actions available for that item. Tap the action you want to perform on the pop-up menu that appears.
The stylus tip can also be used to press the reset button or set the On/Off switch.
Country: Flag Vietnam
