HP iPAQ Pocket PC h1900 Series - Voice Recording
A voice or any other sound can be recorded as a note within the Calendar, Contacts, Notes, and Tasks applications. In the Notes application, it is possible to create stand-alone recordings, which are stored as separate .WAV files in File Explorer.
Making a recording
  1. From the Start menu, tap Notes.
  2. Tap the Cassette Tape icon located at the bottom of the screen to see the recording controls.
    Figure : Cassette Tape icon
  3. Tap the Record icon to start recording.
  4. Position the microphone to record voice or other sounds.
  5. Tap the Stop icon to finish recording.
    To improve the quality of the recording, tap Settings, System, iPAQ Audio, then Microphone AGC.
Listening to a recording
  2. Tap a recording.
  3. Tap the Speaker icon to listen to a recording.
