HP and Compaq Desktop PCs - Keyboard Keys Do Not Work Correctly After Enabling FilterKeys
After enabling FilterKeys, the keyboard keys may not work correctly:
  • Typed characters no longer repeat when holding down a key.
  • Typed characters are slow to appear on the screen.
  • Some key presses do nothing.
  • Stopwatch icon appears in the system tray (next to the time).
Follow these steps to resolve this issue:
  1. Double-click the stopwatch icon in the taskbar.
    Or
    Click Start, Control Panel, and then click Accessibility Options.
    The Accessibility Options window opens.
  2. Click the Keyboard tab in the Accessibility Options window, then uncheck the box next to Use FilterKeys.
    Figure : Accessibility Options: FilterKeys
  3. Click Apply.
The keyboard should now function normally.
Country: Flag Vietnam
