    Looking for Site Help?
Printer Specifications for HP Officejet 5500 All-in-One Printer Series
HP Officejet 5500 series product models
  • HP Officejet 5510
  • HP Officejet 5510xi
  • HP Officejet 5510v
  • HP Officejet 5505
  • HP Officejet 5508
  • HP Officejet 5515
Some models are not available in every region/country.
Minimum system requirements - Windows
Windows 98
Windows 98 SE
Windows Me
Intel Pentium II, Celeron, or compatible processor
64 MB RAM
700 MB free hard disk space plus an additional 50 MB free for full color scanning
Available USB port
CD-ROM drive
SVGA 800 x 600 monitor with 16-bit color depth
Microsoft Internet Explorer 5.01 or higher
Windows 2000
Windows XP1
128 MB RAM
Available USB port
CD-ROM drive
1 Home, Professional, and Media Center Edition
Recommended
  • Intel Pentium III or higher processor
  • 256 MB RAM
  • 1 GB free hard disk space plus an additional 50 MB free for full color scanning
  • Internet access
  • Sound card
Minimum system requirements - Macintosh
OS 9.11
OS X (10.1.x or higher)
OS 10 (10.2.x or higher - 10.2.3 or higher recommended) and 10.3.x
G3 processor or higher
64 MB RAM for OS 9
128 MB RAM for OS X
200 MB free disk space for OS 9 plus an additional 50 MB free for full color scanning
100 MB free disk space for OS X plus an additional 50 MB free for full color scanning
Available USB port
CD-ROM drive
800 x 600 display resolution with 16-bit color depth
Recommended
  • G4 processor or higher
  • 128 MB RAM for OS 9
  • 256 MB RAM for OS X
  • Internet access
  • Sound card
1 Macintosh OS 9.0 and earlier not supported.
Printing specifications
  • Method: Drop-on-demand thermal inkjet.
  • Language: LIDIL (Lightweight Imaging Device Interface Language)
  • Print speed (varies by model): 17 ppm black / 12 ppm color (Fast mode)
  • Print speeds vary according to the complexity of the document.
  • Up to 4800 x 1200 optimized dpi color with 1200 input dpi.
Print cartridge part numbers
Print cartridge
HP part number
HP 56 black print cartridge (19 ml)
C6656A
HP 57 tri-color print cartridge (17 ml)
C6657A
Duty cycle
1,600 printed pages per month maximum
I/O interface
USB (USB 1.1 and 2.0 compatible)
HP recommends using a USB cable less than or equal to 3m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Copying specifications
General copy features
  • Walk-up black and white or color copying
  • Copy speed (varies by model): 12 cpm black / 10 cpm color (Fast mode)
  • Copy speeds vary according to the complexity of the document
  • Reduce/Enlarge 25-400 percent from the glass; 50-200 percent from the automatic document feeder (ADF)
  • Digital image processing
  • Fit to page (from the glass only)
Scanning specifications
  • Image editor included
  • Integrated OCR package
  • Contact image sensor (CIS)
  • Twain compliant interface
  • Scan speeds vary according to the complexity of the document
  • Resolution: 600 x 2400 ppi maximum (19,200 ppi)
  • Bit depth: 36 bits color; 12 bits grayscale
  • Maximum scan size from the glass: 216 x 297 mm (8.5 x 11.7 inches)
  • Maximum scan size from the ADF: 216 x 356 mm (8.5 x 14 inches)
Faxing specifications
  • Walk-up black and white or color faxing.
  • Confirmation and activity reports.
  • CCITT/ITU Group 3 fax with error correction mode (ECM).
  • 33.6 Kbps transmission speed.
  • Three seconds per page speed at 33.6 Kbps (based on ITU-T Test Image 1 at standard resolution. More complicated pages or higher resolution take longer and use more memory.)
  • Ring detect with automatic fax/answering machine switching.
Paper specifications
Paper tray capacities
Type
Paper weight
Input tray
Output tray
Plain paper
70 to 90 gsm (20 to 24 lb.)
100
25
Cards
200 gsm (110 lb.)
20
10
Envelopes
75 to 90 gsm (20 to 24 lb.)
10
5
Transparency film
N/A
20
10
Transparency film
N/A
20
10
Transparency film
236 gsm (145 lb.)
20
10
Automatic document feeder (ADF) paper capacity
Type1
Paper weight
quantity
Letter
20
Legal
20
A4
20
1 ADF accepts plain paper only. It does not accept photo papers, transparency film, envelopes, or labels.
Paper sizes
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. 9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency films
A4: 210 x 297 mm
102 x 279 mm (4 x 6 inches)
Labels
A4: 210 x 297 mm
Print margin specifications
Paper size
Top
Bottom
Left/Right side
US Letter
US Legal
US Executive
1.8 mm (.07 inch)
11.7 mm (.46 inch)
6.4 mm (.25 inch)
ISO A4
ISO A5
JIS B5
1.8 mm (.07 inch)
11.7 mm (.46 inch)
3.2 mm (.13 inch)
Envelopes
3.2 mm (0.13 inches)
11.7 mm (0.46 inches)
Cards
1.8 mm (.07 inch)
Physical specifications
Dimension
Measure
Height
32.1 cm (9.1 inches)
Width
45.3 cm (17.8 inches)
Depth
With paper trays and feeder closed: 28.6 cm (11.2 inches)
With paper trays and feeder extended: 45 cm (17.7 inches)
5.5 kg (12 pounds)
Power specifications
  • Power consumption: 75 W maximum
  • Input voltage: AC 100 to 240 volts - 1 A 50-60 Hz, grounded
  • Output voltage: DC 32 volts === 940 mA, DC 16 volts === 625 mA
Environmental specifications
  • Recommended operating temperature range: 15 to 32 degrees Celsius (59 to 90 degrees Fahrenheit)
  • Allowable operating temperature range: 5 to 40 degrees Celsius (41 to 104 degrees Fahrenheit)
  • Humidity: 15 to 85 percent RH non-condensing
  • Non-operating (storage) temperature range: minus 40 to 60 degrees Celsius (minus 40 to 140 degrees Fahrenheit)
  • In the presence of high electromagnetic fields it is possible the output from the HP Officejet may be slightly distorted.
Country: Flag Vietnam
