HP IP/IPX Printer Gateway - Discontinued, Files Installed for Version 3.00a
HP Gateway Discontinuance
HP has a strong commitment to provide support for Novell products. With this commitment in mind, HP has been providing the HP IP/IPX Printer Gateway for NDPS (HP Gateway) to enable printing on Novell networks. However, after careful testing and evaluation, HP believes that the Novell SNMP Printer Gateway (Novell Gateway) is the preferred solution for enabling printing on Novell networks. Therefore, the HP Gateway product has been discontinued as of January 1, 2005.
Customers are encouraged to migrate to the Novell Gateway as soon as possible. For information about migrating to the Novell Gateway, click here to go to the Novell support Web site. Search for NDPS Printer Agent Conversion Utility.
Hardware requirements
  • HP Jetdirect print servers
  • IPX
  • The HP Printer Gateway supports most HP Jetdirect print servers. However, some of these older print servers must be upgraded or replaced.
    TCP/IP
  • To print through TCP/IP, this protocol must be supported on the HP Jetdirect print server. Most of the HP Jetdirect print servers support TCP/IP, with the exception of the HP Jetdirect 150X (HP product number J2592A) and some older single-protocol HP Jetdirect print servers.
To find out if IPX or TCP/IP is supported on an HP Jetdirect print server, print its Configuration page.
NetWare operating system and client supported by the HP Printer Gateway
The HP Printer Gateway supports the following Novell NetWare versions:
  • NetWare 5.0 (see "Section G: Special notes" for workaround)
  • NetWare 5.1 with support pack 6 or later
  • NetWare 6.0 with support pack 3 or later
The HP Printer Gateway supports the following Novell Client software:
  • Novell Client v 3.32 with support pack 1 or later for Windows 95/98
  • Novell Client v 4.83 with support pack 1 or later for Windows NT, 2000 and XP
Files placed on the NetWare 5.x or 6.0 server
No files are placed on the client during the installation process.
Default path
\Public\Hpgwdoc\Readhpgw.pdf
Readme file for the HP Printer Gateway (this file)
\Public\Win32\Confighp.pd2
HP Printer Gateway configuration snap-in for the NetWare Administrator
\Public\Win32\Hpsnap.pc2
HP Printer Control snap-in for the NetWare Administrator
\Public\Win32\Nls\English\Confighp.hlp
Help file for Confighp.pd2
\Public\Win32\Nls\English\Hppcw32.dll
Resource DLL file for Hpsnap.pc2
\Public\Win32\Nls\English\Hprwin32.dll
Resource DLL file for Confighp.pd2
\Public\Win32\Nls\English\Confighp.ini
Configuration file (created after configuring the HP Printer gateway)
\Public\Win32\Hpgateupdatettcj.exe
Windows program for update "Timeout to Close Job" value on multiple printer agents
\System\Hpgate.nlm
HP Printer Gateway NLM
\System\Hpgconfg.pd0
HP Printer Gateway configuration snap-in for the NDPS Manager
\System\Hpndps.ini
\System\Nls\4\Hpgate.hlp
Help file for Hpgate.nlm
\System\Nls\4\Hpgate.msg
Message file for Hpgate.nlm and Hpgconfg.pd0
\Etc\Hpgerror.log
Error log for the HP Printer Gateway (created by the HP Printer Gateway)
Country: Flag Vietnam
