HP Scanjet 5530 Photosmart Scanner Series - Product Specifications
This document provides the specifications for the HP Scanjet 5530 Photosmart scanner, the Transparent Materials Adapter (TMA), the Automatic Photo Feeder (APF), and the environmental requirements.
HP Scanjet 5530 Digital Flatbed scanner
This section contains the product specifications for the HP Scanjet 5530 Photosmart scanner.
Name
Scanner type
Flatbed
3.7 kg (8.15 lbs)
Weight of scanner with APF
4.9 kg (10.8 lbs)
Size
547.6 mm x 310 mm x 95.6 mm (21.6 x 12.2 x 3.8 inches)
Scanning element
Charged-coupled device
Interface
USB 2.0 Hi-Speed
Optical resolution
2400 x 4800 ppi hardware
Selectable resolution
12 dpi to 999,999 enhanced dpi at 100 percent scaling
AC line voltage
  • 100-120 V 60 Hz – North America
  • 200-240 V 50 Hz – Continental Europe, United Kingdom, Australia
  • 100-240 V 50 Hz/60 Hz – rest of the world
Power consumption
For power consumption data, see the regulatory_supplement.htm file on the HP Photo & Imaging software CD.
The HP Scanjet 5530 Photosmart scanner is ENERGY STAR compliant. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency.
This section contains the product specifications for the TMA.
Name
Media types
Three 35 mm slides or one 35 mm negative strip
Media capacity side
Slide: 1.05 mm to 1.9 mm thick and 49.8 to 50.8 mm on any
Size
287 mm x 84 mm x 50 mm (11.3 x 3.3 x 1.97 inches)
346 g (0.763 lbs)
Power requirements
12.0 VDC, 575 mA, 6.9 watts< (supplied by scanner)
This section contains the product specifications for the APF.
Name
Media types
Agfa, Kodak, Fuji, Konica brand, glossy, matte, photographic emulsion-based print media
Media capacity
89 mm x 127 mm (3 x 5 inches) to 102 mm x 153 mm (4 x 6 inches)
Size
500 mm x 254 mm x 86 mm (19.7 x 10 x 3.4 inches)
1.9 kg (4.2 lbs)
4.9 kg (10.8 lbs)
Power requirements
  • 3.3 V (supplied by scanner)
  • 1.75 mA, 0.578 watts (continuous)
  • 24 V (supplied by scanner) 600 mA
  • 14.4 watts (peak) 500 mA
  • 12 watts (nominal)
Environmental specifications
This section contains the environmental specifications for the HP Scanjet 5530 Photosmart scanner, the TMA, and the APF
Name
Temperature
Operating the scanner and TMA: 10° to 35° C (50° to 95° F)
Operating the APF: 10° to 30° C (50° to 85° F)
Storage: -40° to 60° C (-40° to 140° F)
Relative humidity
Operating the scanner, APF, and TMA: 15 percent to 80 percent noncondensing 10° to 35° C (50° to 95° F)
Storage: up to 90 percent at 0° to 60° C or (32° to 140° F)
Country: Flag Vietnam
