You can print but you cannot preview Lotus 1-2-3 files with the following page formats and sizes:
- 594 mm 841 mm (ISO A1) or larger
- 22 inches 34 inches (ANSI D) or larger
You can neither print nor preview Lotus 1-2-3 files with the following page formats and sizes:
- 841 mm 1188 mm (ISO A0) or larger
- 34 inches 44 inches (ANSI E) or larger
There is a difference between Lotus 1-2-3 and the printer driver in the way they handle certain colors. When these colors are used for solid area fills, they are reported to the printer driver as a mix of colors to be mixed by the printer using a process known as "dithering." When these colors are printed they are not solid and appear to have a very fine pattern.
Issues exist that cause the orientation of some patterns to be printed differently than shown on the screen. Also, page sizes larger than ANSI-C may not print.
