HP Designjet 100, 100plus, 120 and 130 Series Printers - Page Size and Margin Information
Page size and margin information
When entering Width and Length values for a custom paper size, take into account the following limits:
  • The minimum acceptable width for the 100/100plus series is 76 mm (3 inches).
  • The minimum acceptable length for the 100/100plus series is 142 mm (5.6 inches)
  • The maximum acceptable width for the 120/130 series is 625 mm (24.6 inches)
  • The maximum acceptable length for the 120/130 series is 1625 mm (63.98 inches) for sheet paper, or 15240 mm (600 inches) for roll paper (120nr/130nr ONLY)
The application may restrict the maximum length to less than the above figures.
Margins for 100 series
For portrait paper and a landscape drawing, the minimum margins are:
Printer
Top Margin
Bottom Margin
Right/Left Margin
100/100plus series (cut sheet)
5mm = 0.20 inches
12 mm = 0.47 inches
5mm = 0.20 inches
120/130 series (cut sheet)
5mm = 0.20 inches
12 mm = 0.47 inches
5mm = 0.20 inches
120nr/130nr series (roll)
5mm = 0.20 inches
5 mm = 0.20 inches
5mm = 0.20 inches
