HP Scanjet 5550C Series Scanners - Scanning Multi-Page Documents into a Single TIF File in Windows XP
Purpose
This document explains how to scan multiple pages into a single file when using the TIF format in Windows XP. In Windows XP, use the Windows Imagine Acquisition (WIA) application to save multiple page files in a TIF format.
WIA will initially save all the pages scanned as separate files, but then will combine all of the individual files into a single file after the scanning is complete.
Instructions
  1. Click Start, Control Panel, and then Printers and Other Hardware. The Printers and Other Hardware window will open.
    If scanning multi-page TIFF files on a regular basis, create a shortcut on the Desktop by right-clicking the Scanners and Cameras icon and selecting Create Shortcut. Click Yes when prompted to place the shortcut on the Desktop.
  2. Double-click the Scanners and Cameras folder to open it. The HP Scanjet 5550c should be listed there.
  3. Double-click the HP Scanjet 5550c scanner to launch the Camera and Scanner Wizard. This starts the WIA application.
  4. Click Next. The Scanning Preferences window will open.
  5. Select Black and White picture or Text, and then select Document Feeder from the menu in the Paper Source box.
  6. Click Next. The Picture Name and Destination window will open.
  7. Follow the instructions on the screen, selecting TIF in the File Format box.
  8. Click Next. The scanner will scan directly to the folder named in step 7.
  9. During the scan, the images will be saved separately and only combined into one file after the last page is scanned.
Country: Flag Vietnam
