    Looking for Site Help?
HP Scanjet 2400, 3670, 3690, and 3970 Digital Flatbed Series Scanners - Product Specifications and Minimum System Requirements
Regulatory information
Regulatory information is located on the HP Photo & Imaging software CD that comes with the scanner. On the CD, browse for the file named regulatory_supplement.htm.
Product specifications
Scanner specifications
Name
Scanner type
Flatbed
Weight (without lid)
HP Scanjet 2400 scanner
1.7 kg (3.74 pounds)
HP Scanjet 3670 scanner
2.1 kg (4.62 pounds)
HP Scanjet 3690 scanner
HP Scanjet 3970 scanner
2.3 kg (5.06 pounds)
Maximum item size (without lid)
280 x 486.5 x 52 mm (11.0 x 19.1 x 2.0 inches)
286 x 464 x 53 mm (11.2 x 18.2 x 2.1 inches)
297.7 x 476.5 x 65 mm (11.7 x 18.7 x 2.6 inches)
Scanning element
Charged-coupled device
Interface
USB
USB
USB
Hi-Speed USB
Optical resolution
1200 dpi
1200 dpi
1200 dpi
2400 dpi
Selectable resolution
12 dpi to 999,999 dpi at 100 percent scaling
AC line voltage
100-120 V 60 Hz
North America
200-240 V 50 Hz
Continental Europe, United Kingdom, Australia
100-240 V 50 Hz/60 Hz
rest of the world
Power consumption
For power consumption data, see the regulatory_supplement.htm file on the HP Photo & Imaging software CD.
ENERGY STAR
All HP Scanjet 2400, 3670, 3690, and 3970 scanners are ENERGY STAR compliant. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency.
Transparent Materials Adapter (TMA) specifications
The HP Scanjet 2400 digital flatbed scanner does not have a TMA.
The following specifications refer to the document lid transparent materials adapter (TMA) and not the scanner.
Name
Media types
1 slide/up to 2 frames of a 35 mm negative
Media capacity
Slide: 1.05 to 1.9 mm thick and 49.8 to 50.8 mm on any side
Size
244 x 430 x 34 mm (9.6 x 16.9 x 1.3 inches)
244 x 430 x 39 mm (9.6 x 16.9 x 1.5 inches)
255 x 430 x 39 mm (10.0 x 16.9 x 1.5 inches)
0.65 kg (1.43 pounds)
scanner 0.85 kg (1.87 pounds)
scanner 0.90 kg (1.98 pounds)
Power requirements
12.0 VDC, 340 mA, 4.22 watts (supplied by scanner)
Environmental specifications for the scanner and TMA
Name
Temperature
Operating: 10° to 35° C (50° to 95° F)
Storage: -40° to 70° C (-40° to 158° F)
Relative humidity
Operating: 15 percent to 80 percent noncondensing 10° to 35° C (50° to 95° F)
Storage: up to 90 percent at 0° to 65° C or (32° to 149° F)
Minimum system requirements - PC
  • Pentium II Celeron or compatible (Recommended Pentium IIII 333MHz for Microsoft Windows 98, ME, 2000, XP
  • Microsoft Windows 98, ME, 2000, XP
  • 64 MB RAM (Recommended 256 MB RAM)
  • 175 MB hard disk space, plus 50 MB for full-color scanning
  • CD-ROM drive
  • 800 x 600 SVGA monitor (Windows)
  • USB port on PC (Sound card recommended)
  • IE 5.0 or later
  • Acrobat Reader 4 or later
Minimum system requirements - Macintosh
  • 233 MHz Power PC processor
  • Mac OS 9.1 or higher, or Mac OS 10.1.5 or 10.2 or higher
  • 240 MB free hard disk space
  • 64 MB RAM (Recommended 128 MB RAM) for OS 9
  • 128 MB RAM for Mac OS X
  • CD-ROM drive
  • 800 x 600, 16-bit color SVGA monitor
  • HP Memories Disc Creator requires a CD-Writer and 700 MB additional free hard disk space
  • USB port on Mac (Sound card recommended)
  • IE 5.0 or later
Country: Flag Vietnam
