    Corrija errores en Win 10
    Resuelva problemas de actualización  de Windows 10  en un PC HP – haga clic aquí
HP ScanJet Pro 2000 s2, 3000 s4, N4000 snw1 / HP ScanJet Enterprise Flow 5000 s5, 7000 s3, N7000 snw1 - Scanner software (macOS)
The product is compliant with Apple AirScan functionality. Without installing any additional software, you can scan using Image Capture or other ICA-compliant applications.
To take advantage of all features of your scanner, HP recommends installing the HP provided scan solution, including HP Easy Scan and HP Utility.
HP Easy Scan
Scan documents and photos, and manage scan shortcuts.
HP Utility
You can use the HP Utility when the scanner is connected with a USB cable.
The Maintenance pane in HP Utility displays the scanner usage, maintenance history, and notifies the user when maintenance is due. The notification displays in HP Utility when the Maintenance pane is selected.
HP Utility allows you to configure the scanner and assign the Scan button workflow on a Mac. HP Utility is available in the Applications > HP folder.
País/región: Flag Uruguay
