This document applies to Sprout by HP.
advertencia:Make sure the computer is disconnected from power before starting.
atención:This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a noncarpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
atención:Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
nota:For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Step 1
Remove the motherboard EMI shield.
For detailed instructions to remove the motherboard EMI shield, see the HP support document, Remove and Replace the motherboard EMI shield for HP Sprout by HP.
Step 2
Pull the USB dongle cable connector out of its cable guide on the side of the fan.
Step 3
Detach the fan connector from the motherboard.
Step 4
Remove the three silver torx head screws that secure the fan to the middle frame.
Step 5
Pull the system fan out of the computer.
Step 1
To replace the system fan place the fan carefully back onto its standoffs.
Step 2
Secure the fan with its three silver torx head screws.
Step 3
Replace the system fan connector to the motherboard.
Step 4
Replace the USB dongle cable into its cable guide on the side of the fan.
Step 5
Replace the parts that were removed to gain access to the system fan.
For detailed instructions to replace the motherboard EMI shield and the rest of the parts, see the HP support document, Remove and Replace the motherboard EMI shield for HP Sprout by HP.
