Specification
Dimensions (W x D x
H)
8.34 x 11.22 x 0.80 in (at front) / 212 x 285 x 22.2 mm (at front)
Starting at 1.40 kg (3.08 lb) (weight will vary by configuration)
- ${title}
- ${title}
- ${title}
- ${title}
HP EliteBook Revolve 810 G2 Tablet - Specifications
Physical specifications
Display specifications
Specification
Active area
25.61 x 14.40 cm (9.88 x 5.67 in)
Dimensions (W x H)
29.3 x 16.5 cm ( 11.53 x 6.49 in)
Diagonal size
29.46 cm ( 11.6 in)
Contrast ratio
300:1 (typical)
Refresh rate
60 Hz
Brightness
400 nit (typical)
Pixel resolution
Backlight
LED
Viewing angle
40/40/15/30 (Left/Right/Down/Up) (typical)
Electrical specifications
Specification
Stand-alone power
requirements (AC
Power)
Storage and drives specifications
Specification
Drive weight
10 g
Capacity
128GB
Height
0.091 in (2.3 mm)
Width
0.87 in (22 mm)
Interface
SATA 3 (6 Gb/s)
Performance
Logical blocks
250,069,680
Operating temperature
0° to 70°C ( 32° to 158°F)
Features
ATA Security; ATA-8; SATA 3.0; DIPM; TRIM
Drive Weight
10 g
Capacity
180GB
Height
0.091 in (2.3 mm)
Width
0.87 in (22 mm)
Interface
SATA Gen 3 (6 Gb/s)
Performance
Logical blocks
351,651,888
0° to 70°C (32° to 158°F )
Features
ATA Security; ATA-8, SATA 3.0; DIPM; TRIM
Drive weight
10 g
Capacity
256GB
Height
0.091 in (2.3 mm)
Width
0.87 in (22 mm)
Interface
SATA Gen 3 (6 Gb/s)
Performance
Logical blocks
500,118,192
Features
Audio/Multimedia specifications
Audio
DTS Studio Sound (Windows OS only)
Audio output quality
Integrated stereo
speakers
Environmental specifications
Operating
Temperature
Relative humidity
10% to 90%, non-condensing
Shock
40 G, 2 ms, half-sine
Random vibration
0.75 grms
Altitude (unpressurized)
-15.24 to 3,048 m ( -50 to 10,000 ft)
Non-operating
Temperature
-20° to 60°C ( -4° to 140°F)
Relative humidity
38.7°C ( 5% to 95%, 101.6°F) maximum wet bulb temperature
Shock
200 G, 2 ms, half-sine
Random vibration
1.50 grms
-15.24 to 12,192 m ( -50 to 40,000 ft)
Safety certifications
Planned industry
standard
certifications
Link to product overview information
- ${title}
- ${title}
- ${title}
País/región:
Uruguay
- ${title}
hp-hero-support-search
- ${title}
