If you go to the front panel and press
, then
, then Paper > Form feed and cut, the printer advances the paper and makes a straight cut across the front edge. There are several possible reasons why you might want to do this.
![](/wcc-assets/document/images/33/c02541960.png)
![](/wcc-assets/document/images/549/c02541964.png)
To trim the leading edge of the paper if it is damaged or not straight.
To feed and cut the paper when the automatic cutter has been disabled.
To cancel the waiting time and print the available pages immediately, if the printer is waiting to nest more pages.
nota:The printheads are serviced after each print, and the paper cannot be cut until the process completes, so you may notice a delay.
atención:Remove the cut piece from the output tray. If strips or short prints are left in the output tray the printer could jam.
Figura : Remove the cut strip
![](/wcc-assets/document/images/739/c02541940.png)
nota:Photo and coated papers require careful handling: they can easily be marked or scratched, especially if touched soon after printing.
nota:To move the paper without cutting it, see Move the paperMove the paper.
