    Estamos actualizando nuestro sitio
    Si experimenta algún error durante este tiempo, inténtelo de nuevo más tarde.
    Solucione errores intermitentes en la cola de impresión/con el spooler de impresión que podrían causar fallos en los trabajos de impresión tras una actualización de Windows. Haga clic aquí
    Corrija errores en Win 10
HP EliteBook 8440p Notebook PC - Removing and Replacing Primary Memory Board
This document is provided to assist in removing and replacing the primary memory board for the HP EliteBook 8440p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1 and P0) screwdrivers
Parts required
The replacement part number will vary depending on the primary memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Primary memory modules (PC3-10600 DDR3 1333-MHz)
1024MB
598859-001 (Original)
Yes
2048MB
598856-001 (Original)
Yes
4096MB
599092-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the primary memory board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Primary memory board from the menu on the upper left hand side of the screen.
Click here to view the primary memory board removal video (right-click on the link to open in a new window/tab).
Primary memory board removal
      atención:
  2.   atención:
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  3. Push both arms outward simultaneously to release the memory board to the spring tension position.
  4. Grasp the memory board by the edges and pull gently to remove it.
  5. Place the memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the memory board from the static dissipative bag.
      atención:
  2. Align the notch in the memory board with the key in the memory board slot on the system board.
  3. At an angle, gently insert the memory board into its slot on the system board
  4. Press the memory board down to latch the arms.
  5. Replace the keyboard.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
Parts return
País/región: Flag Uruguay
