HP EliteBook 8440p Notebook PC - Removing and Replacing Optical Drive
This document is provided to assist in removing and replacing the Optical drive for the HP EliteBook 8440p Notebook PC.
Minimum skill level
Tools required
Captive, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the Optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Blu-ray ROM DVD±RW SuperMulti DL Drive
594040-001 (Modified)
Yes
Blu-ray R/RE DVD±RW SuperMulti Drive
594041-001 (Modified)
Yes
DVD-ROM Drive
594042-001 (Modified)
Yes
DVD±RW and CD-RW SuperMulti Double-Layer Combo Drive with LightScribe
594043-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the optical drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Optical Drive from the menu on the upper left hand side of the screen.
Click here to view the optical drive removal video (right-click on the link to open in a new window/tab).
Optical drive removal
      atención:
  2. On the bottom of the notebook, loosen the captive P1 Phillips-head screw that secures the optical drive to the bottom of the base enclosure.
  3. Turn the notebook right side up.
  4. Insert a paper clip or thin metal rod into the manual release hole on the front bezel of the optical drive and press firmly.
  5. Grasp the side rails of the drive tray to pull the optical drive out and remove.
  6. Push the drive tray back into the optical drive.
Optical drive replacement
  1. Insert the optical drive into the base enclosure until the connector is seated.
  2. Turn the notebook upside down.
  3. Replace the two P1 Phillips-head screws that secures the optical drive to the bottom of the base enclosure.
Parts return
País/región: Flag Uruguay
