HP EliteBook 8440p Notebook PC - Removing and Replacing Wireless WAN Module
This document is provided to assist in removing and replacing the wireless WAN module for the HP EliteBook 8440p Notebook PC.
Minimum skill level
Tools required
  • Small, Phillips-head (P00 and P1) screwdrivers
  • Tweezers
Parts required
The replacement part number will vary depending on the wireless WAN module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Qualcomm EV-DO HSPA minicard
531993-001 (Modified)
Yes
Ericsson F3607 SDG 900 HSPA minicard
574249-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the wireless WAN module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Wireless WAN module from the menu on the upper left hand side of the screen.
Click here to view the wireless WAN module removal video (right-click on the link to open in a new window/tab).
Wireless WAN module removal
      atención:
  2. Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Lift the hard disk drive cover and remove it.
  4. Lift the wireless WAN module cover and remove it.
  5. Carefully disconnect the two wireless antenna cables from the wireless WAN module by grasping the connectors with a small pair of needle nose pliers or tweezers.
    Use care when disconnecting the wireless antenna cables from the wireless WAN module. Damaged cables or connectors can degrade notebook performance.
  6. Remove the two 4mm P1 Phillips-head screws that secure the wireless WAN module to the system board and allow it to release to the spring tension position.
  7. Grasp the wireless WAN module by the edges and pull gently to remove it.
  8. Place the wireless WAN module in a static dissipative bag.
Wireless WAN module replacement
  1. Remove the wireless WAN module from the static dissipative bag.
  2. Locate the alignment slot and align it to the board receptacle.
  3. Grasp the wireless WAN module by the edges and push gently to replace it.
  4. Press the wireless WAN module down and replace the two 4mm P1 Phillips-head screws that secure the wireless WAN module to the system board.
  5. Reconnect the two wireless antenna cables to the wireless WAN module.
    Use care when connecting the wireless antenna cables to the wireless WAN module. Damaged cables or connectors can degrade notebook performance.
    Ensure the wireless WAN antenna cables are inserted into the guide notches located in the upper left corner of the Wireless WAN module bay.
  6. Toe the wireless WAN module cover into the enclosure.
  7. Toe the hard disk drive cover into the base enclosure.
  8. Tighten the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
Parts return
País/región: Flag Uruguay
