HP EliteBook 8440p Notebook PC - Removing and Replacing Wireless LAN Module
This document is provided to assist in removing and replacing the Wireless LAN module for the HP EliteBook 8440p Notebook PC.
Minimum skill level
Tools required
  • Small, Phillips-head (P00 and P1) screwdrivers
  • Tweezers
Parts required
The replacement part number will vary depending on the Wireless LAN module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Intel a/g/n (2x2) for use in all countries and regions
572509-001 (Modified)
Yes
Intel a/g/n (3x3) for use in all countries and regions
572511-001 (Modified)
Yes
Intel a/b/g for use in Russia
572510-001 (Modified)
Yes
Broadcom BCM4312 802.11b/g WLAN module
504593-003 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the wireless LAN module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Wireless LAN module from the menu on the upper left hand side of the screen.
Click here to view the wireless LAN minicard removal video (right-click on the link to open in a new window/tab).
Wireless LAN module removal
      atención:
  2. Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Lift the hard disk drive cover and remove it.
  4. Lift the wireless LAN module cover and remove it.
  5. Carefully disconnect the two wireless antenna cables from the wireless LAN module by grasping the connectors with a small pair of needle nose pliers or tweezers.
    Use care when disconnecting the wireless antenna cables from the wireless LAN module. Damaged cables or connectors can degrade notebook performance.
  6. Remove the two 3mm P1 Phillips-head screws that secure the wireless LAN module to the system board and allow it to release to the spring tension position.
  7. Grasp the wireless LAN module by the edges and pull gently to remove it.
  8. Place the wireless LAN module in a static dissipative bag.
Wireless LAN module replacement
  1. Remove the wireless LAN module from the static dissipative bag.
  2. Locate the alignment slot and align it to the board receptacle.
  3. Grasp the wireless LAN module by the edges and push gently to replace it.
  4. Press the wireless LAN module down and replace the two 3mm P1 Phillips-head screws that secure the wireless LAN module to the system board.
  5. Reconnect the two wireless antenna cables to the wireless LAN module.
    Use care when connecting the wireless antenna cables to the wireless LAN module. Damaged cables or connectors can degrade notebook performance.
    Ensure the wireless LAN antenna cables are inserted into the guide notches located in the upper left corner of the Wireless LAN module bay.
  6. Toe the wireless LAN module cover into the enclosure.
  7. Toe the hard disk drive cover into the base enclosure.
  8. Tighten the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
Parts return
País/región: Flag Uruguay
