HP EliteBook 2540p Notebook PC - Removing and Replacing the Optical Drive
This document is provided to assist in removing and replacing the optical drive for the HP EliteBook 2540p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
DVD-ROM drive - SATA interface, 9.5 mm tray load - Includes bezel and bracket - For use only on models equipped with a low voltage (25 W) processor
598775-001 (Modified)
Yes
DVD±RW and CD-RW SuperMulti Double-Layer combination optical drive - SATA interface, 9.5 mm tray load - Includes bezel and bracket - For use only on models equipped with a low voltage (25 W) processor
598776-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the optical drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Optical drive from the menu on the upper left hand side of the screen.
Click here to view the optical drive removal video (right-click on the link to open in a new window/tab).
Optical drive removal
      atención:
  2. On the bottom of the notebook, loosen the three captive P1 Phillips-head screws identified with a memory icon that secure the memory cover to the bottom of the notebook and remove the memory cover.
  3. Remove the 4.5 mm P1 Phillips-head screw inside the memory bay that secures the optical drive to the base enclosure.
  4. Remove the 4.5 mm P1 Phillips-head screw near the right front corner of the base enclosure that secures the optical drive to the base enclosure.
  5. Grasp the optical drive bezel and slide the optical drive out of the base enclosure.
Optical drive replacement
  1. Insert the optical drive into the base enclosure until its connector is firmly seated.
  2. Replace the 4.5 mm P1 Phillips-head screw near the right front corner of the base enclosure that secures the optical drive to the base enclosure.
  3. Replace the 4.5 mm P1 Phillips-head screw inside the memory bay that secures the optical drive to the base enclosure.
  4. Replace the memory cover by tightening the three captive P1 Phillips-head screws on the bottom of the notebook that secures the memory cover.
Parts return
País/región: Flag Uruguay
