    Solucione errores intermitentes en la cola de impresión/con el spooler de impresión que podrían causar fallos en los trabajos de impresión tras una actualización de Windows. Haga clic aquí
    Corrija errores en Win 10
HP EliteBook 2540p Notebook PC - Removing and Replacing the Bluetooth Module
This document is provided to assist in removing and replacing the bluetooth module for the HP EliteBook 2540p Notebook PC.
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the bluetooth module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Bluetooth SB module
537921-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the bluetooth module, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Bluetooth module from the menu on the upper left hand side of the screen.
Click here to view the bluetooth module removal video (right-click on the link to open in a new window/tab).
Bluetooth module removal
      atención:
  2. On the bottom of the notebook, loosen the captive P1 Phillips-head screw that secures the Bluetooth module cover to the base enclosure.
  3. Turn the Bluetooth module cover over so you have access to the Bluetooth module.
  4. Using a flat, non-metallic tool, remove the Bluetooth module from its cradle on the Bluetooth module cover.
  5. Remove the Bluetooth module cover.
  6. Disconnect the Bluetooth cable from its connector on the Bluetooth module.
  7. Remove the Bluetooth module and place it in a static dissipative bag.
Bluetooth module replacement
  1. Remove the Bluetooth module from the static dissipative bag.
  2. Connect the Bluetooth cable to its connector on the Bluetooth module.
  3. Holding the Bluetooth module cover in one hand, place the Bluetooth module into its cradle on the Bluetooth module cover.
  4. Toe the tab on right side of the Bluetooth module cover into the slot in the base enclosure and lower the Bluetooth module cover into position.
      atención:
    Ensure that the Bluetooth module cable is free from being pinched between the Bluetooth module cover and base enclosure.
  5. Tighten the captive P1 Phillips-head screw that secures the Bluetooth module cover to the base enclosure.
Parts return
País/región: Flag Uruguay
