    Solucione errores intermitentes en la cola de impresión/con el spooler de impresión que podrían causar fallos en los trabajos de impresión tras una actualización de Windows. Haga clic aquí
    Corrija errores en Win 10
HP EliteBook 2540p Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP EliteBook 2540p Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery (Primary) - 3-cell lithium-ion (Li-Ion), 2.8 Ah, 31 Wh
492548-001 (Modified)
Yes
Battery (Primary, XL) - 3-cell lithium-ion (Li-Ion), 2.8 Ah, 28 Wh
593584-001 (Modified)
Yes
Battery (Primary, XL) - 6-cell lithium-ion (Li-Ion), 2.8 Ah, 55 Whr
593585-001 (Modified)
Yes
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 2.8 Ah, 62 Whr
593586-001 (Modified)
Yes
Battery (Primary) - 9-cell lithium-ion (Li-Ion), 2.8 Ah, 93 Whr
593587-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
      atención:
  2. Slide both battery locking latches toward the outside of the notebook to partially eject the battery.
  3. Slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until it is properly seated and the locking latches click.
Parts return
País/región: Flag Uruguay
