Features
Dimensions (HxWxD)
0.91 (at front) x 10.30 x 7.09 in
23.2 (at front) x 262 x 180 mm
nota: |
Stand-Alone Power
Requirements (AC Power)
Temperature
Operating:32° to 95° F (0° to 35° C).
Non-operating: -4° to 140° F (-20° to 60° C).
Relative Humidity
Operating: 10% to 90%, non-condensing.
Non-operating:
5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature.
Altitude
(unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m).
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m).
Security
Standard Features:
- ${title}
- ${title}
- ${title}
- ${title}
HP Mini 5101 - Specifications
Hardware Specifications
Communications
Features
HP un2400
EV-DO/HSPA Mobile Broadband Module
Integrated WWAN module with Gobi global mobile Internet technology that provides worldwide connection to both CDMA (EVDO) and UMTS (HSPA) wireless networks.
Two 850/900/1800/1900/2100 MHz antennas integrated in the top of the display panel support current and future WWAN technologies.
All 802.11 integrated wireless LAN options
Intel WiFi Link 5100
Integrated support for 802.11 a, b and g
Cisco Compatible Extensions support
Up to 54 mbps data rate.
Broadcom 4322G 802.11a/b/g/draft-n
Wi-Fi Adapter
Integrated support for 802.11 a, b, g, and n draft 2.0*
Up to 300 mbps data rate
HP Integrated Module with Bluetooth Wireless Technology
Bluetooth Specification v2.1 compliant
Works with a wide range of Bluetooth devices
nota: |
Audio/Visual
Features
Audio/Visual
Link to product overview
- ${title}
- ${title}
- ${title}
País/región:
Uruguay
- ${title}
hp-hero-support-search
- ${title}
