    ¡Cree una cuenta HP hoy!
HP Photosmart C5200 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Prepare the control panel
  • Connect the power cord and adapter
  • Turn the product on
  • Load plain white paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
Remove all tape, tabs, and protective film from the lid and from the front and back of the product.
Figura : Remove tape
Remove packing tape
The contents may vary by country/region. Refer to the packaging for the actual contents.
Step three: Prepare the control panel
  1. If the control panel faceplate is not attached, place the faceplate in position, and then press down firmly on all the edges to secure it.
    Figura : Secure the faceplate
  2. Adjust the angle of the display for viewing.
    Figura : Adjust the display
    Tilt the control panel display
    Pay attention to messages on the display during the setup process.
Step four: Connect the power cord and adapter
Connect the power cord and adapter.
Figura : Connect the power cord
Step five: Turn the All-in-One on
Press the On () button to turn on the product.
Figura : Press the On button
Press the On button
If the control panel display prompts you to set your language and country/region, use the arrow keys to make selections in the menu, and then press OK to confirm your selections.
Step six: Load plain white paper
  1. Raise the output tray to load paper into the main input tray.
  2. Insert the stack of paper into the main input tray with the short edge forward and the side to be printed on facing down. Slide the stack forward until it stops.
    Figura : Insert the paper
    Insert plain white paper
  3. Slide the paper-width guide inward until it stops at the edge of the paper.
    Do not overload the main input tray. Make sure the stack of paper fits within the main input tray and is no higher than the top of the paper-width guide.
    Figura : Slide the paper-width guide inward
    Slide in the paper width guide
      atención:
    Make sure that the product is idle and silent when loading paper into the main input tray. If the product is servicing the cartridges or is otherwise engaged in a task, the paper stop inside the product might not be in place. If the stop is not in place, the stack can be pushed too far forward, causing the product to eject blank pages.
  4. Lower the output tray.
  5. Pull the output tray extension out as far as it goes.
Step seven: Install the cartridges
The product must be turned on and the CD/DVD tray must be in the up position before you can insert the cartridges.
  1. Lift the cartridge door.
    Figura : Raise the cartridge door
    Raise the top cover of the product
  2. Remove the tape from the cartridges.
    Figura : Remove the tape
    Remove protective tape from cartridges
      atención:
    Do not touch the copper-colored contacts or re-tape the cartridges.
    Figura : Do not touch ink nozzles or copper-colored contacts
    Do not touch electrical contacts or ink nozzles
  3. With the HP logo on top, insert the tri-color cartridge in the left slot and the black or photo cartridge in the right slot.
    Figura : Insert the tri-color cartridge
    Insert the tri-color cartridge in the left slot
  4. Push the cartridges in firmly until they snap into place.
    Figura : Push each cartridge in firmly
    Push each cartridge firmly into place
    Figura : Correctly installed cartridges
  5. Close the cartridge door.
  6. Press OK when prompted to confirm the installation of genuine HP cartridges.
Step eight: Align the cartridges
  1. On the product control panel, press OK at each of the prompts tostart cartridge alignment.Wait a few minutes while the alignment page prints.
  2. Check thecontrol panel display for the status, and then press OK.
País/región: Flag Uruguay
