  • Comentarios
HP PSC 1310 Series - Installing Cartridges
Install the cartridges as soon as possible after you remove the tape. Remove only the tape! Do not attempt to remove the copper strip.
Figura : If you have a new print cartridge, remove the tape
Figura : Make sure the printer is turned on
Figura : Open both doors on the printer, then wait a moment for the cartridge carriage to come to the center
Figura : Place the tri-color cartridge in the left slot at a slight angle, then press up and forward until the cartridge snaps into position
Figura : Place the black or photo cartridge in the right slot at a slight angle, then press up and forward until the cartridge snaps into position
Figura : Close the gray door
País/región: Flag Uruguay
