Specification
Preinstalled
Windows 10 Pro 641
Windows 10 Pro (National Academic License) 642
Windows 10 Home 641
Windows 10 Home Single Language 641
Windows 10 (Windows 10 Enterprise available with a Volume Licensing Agreement)1
FreeDOS 1.2
note:1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.2Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Specification
Intel Core i7-8665U vPro processor
1.9 GHz base frequency, up to 4.8 GHz with Intel Turbo Boost
Technology
8 MB L3 cache and 4 cores
Intel UHD Graphics 620
Intel Core i7-8565U processor
1.8 GHz base frequency, up to 4.6 GHz with Intel Turbo Boost
Technology
Intel Core i5-8365U vPro processor
1.6 GHz base frequency, up to 4.1 GHz with Intel Turbo Boost
Technology
6 MB L3 cache and 4 cores
Intel Core i5-8265U processor
1.6 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost
Technology
Integrated with processor
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Specification
Integrated
note: |
Discrete (sold separately or as an optional feature)
AMD Radeon 550X (2 GB GDDR5 video memory)
note: |
Supports
HD decode
DirectX 12
HDMI 1.4b (cable sold separately)
Specification
Touch (sold separately or as an optional feature)
35.56 cm (14.0 in) diagonal FHD IPS eDP Anti-Glare On-Cell WLED-backlit slim touchscreen, 250 nits, 45% NTSC with HD and IR
camera (1920 x 1080)
camera for WWAN (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP WLED-backlit slim touchscreen, 250 nits, 45% NTSC with HD and IR
Non-touch (sold separately or as an optional feature)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare WLED-backlit slim, 250 nits, 45% NTSC
(1920 x 1080)
with HD camera (1920 x 1080)
with HD and IR camera (1920 x 1080)
with HD camera for WWAN (1920 x 1080)
with HD and IR camera for WWAN (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP and PSR anti-glare WLED-backlit ultraslim, 400 nits, 72% NTSC
with ambient light sensor, HD and IR camera (1920 x 1080)
with ambient light sensor, HD and IR camera for WWAN (1920 x 1080)
35.56 cm (14.0 in) diagonal 4K FHD IPS eDP and PSR anti-glare WLED-backlit ultraslim, 400 nits, 72% NTSC
with ambient light sensor, HD and IR camera for WWAN (3840 x 2160)
HDMI 1.4b
Supports resolution up to 4k at 60 Hz via DisplayPort
Supports resolution up to 4k at 30 Hz via HDMI
note:Resolutions are dependent upon monitor capability, and resolution and color depth settings.High-definition (HD) content is required to view high definition images.
Specification
Standard
(2) SODIMMs (customer accessible/upgradeable)
Supports dual-channel memory
Transfer rate up to 2400 MT/s
Configurations
32 GB DDR4-2400 SDRAM (2 x 16 GB)
16 GB DDR4-2400 SDRAM (1 x 16 GB)
16 GB DDR4-2400 SDRAM (2 x 8 GB)
8 GB DDR4-2400 SDRAM (2 x 4 GB)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Maximum
note:Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Specification
Solid State Drive (SSD)
128 GB M.2 SATA-3 M.2 TLC SSD
256 GB PCIe NVMe Value M.2 TLC SSD
256 GB PCIe Gen3 x4 NVMe M.2 TLC SSD
256 GB SATA-3 SED M.2 TLC (Opal 2) SSD
512 GB PCIe Gen3 x4 NVMe M.2 TLC SSD
512 GB PCIe Gen3 x4 NVMe SED M.2 TLC (OPAL 2) SSD
512 GB SATA-3 M.2 TLC (FIPS 140-2) SSD
512 GB M.2 PCIe Value SSD
512 GB Intel PCIe NVMe QLC SSD
1 TB PCIe Gen3 x4 NVMe M.2 TLC SSD
2 TB PCIe Gen3 x4 NVMe M.2 TLC SSD
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Specification
Ports
(1) USB 3.1 Type-C port (with Thunderbolt support)
(2) USB 3.1 Gen 1 (1 charging)
(1) HDMI 1.4b port (cable sold separately)
(1) RJ-45 port
(1) Docking connector
(1) Headphone/microphone combo
(1) AC power port
Specification
Audio
Bang & Olufsen
(3) Multi-array microphone (integrated)
(2) Integrated stereo speakers
Camera
720p HD camera
720p HD IR camera (optional)
note: |
Specification
WLAN
Intel Dual Band Wireless-AC 9560 802.11a/b/g/n/ac (2x2) Wi-Fi and
Bluetooth 5 Combo, vPro
Bluetooth 5 Combo, non-vPro
note: Intel Wi-Fi 6 AX200 802.11a/b/g/n/ac/ax (2x2) and Bluetooth 5 Combo, vPro
Intel Wi-Fi 6 AX200 802.11a/b/g/n/ac/ax (2x2) Bluetooth 5 Combo, non-vPro
note: |
WWAN
Intel XMM 7262 LTE-Advanced Cat 6
Intel XMM 7360 LTE-Advanced Cat 9
note: Intel XMM 7560 LTE-Advanced Pro Cat 16
note: |
Ethernet
Intel I219-LM 10/100/1000 GbE, vPro
Intel I219-LM 10/100/1000 GbE, non-vPro
note: |
NFC
NXP NPC300 Near Field Communication Module
Miracast support
Yes
Specification
HP Premium keyboard
HP Premium Collaboration Keyboard
Backlight (optional)
Spill resistant with drain
Pointing devices
ClickPad with multi-touch gestures enabled (taps enabled as default)
Microsoft Precision Touchpad default gestures support
Function keys
F1 – Display switching
F2 – Blank or privacy
F3 – Brightness down
F4 - Brightness up
F5 - Audio mute/unmute
F6 - Volume down
F7 - Volume up
F8 - Microphone mute/unmute
F9 - Backlight toggle
F10 - Num Lock
F11 - Wireless
F12 - Calendar
Share/Present
Call Answer
Call End
Function Keys
Fn+R - Break
Fn+S - Sys Rq
Fn+C - Scroll Lock
Fn+E - Insert
Fn+W - Pause
Specification
BIOS
HP BIOSphere Gen5
Master Boot Record Security
BIOS Update via Network
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
HP Wireless Wakeup
Absolute Persistence Module
note: |
Communication/connectivity
HP Native Miracast support
HP Connection Optimizer
HP Value add software
HP Image Assistant
HP Hotkey Support
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Sure Click
note: HP Sure Start Gen5 (available on select HP PCs with Intel processors)
HP Sure Recover Gen2
note: HP Sure Run Gen2
HP Sure Sense (requires Windows 10)
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
Ivanti Management Suite
HP Power Manager
HP Management Integration Kit for Microsoft SCCM (available for download)
note: |
Client Security software
Microsoft Defender (opt in and internet connection required for updates)
HP Client Security Suite Gen4 (requires Windows)
HP Security Manager (including Credential Manager and HP Password Manager, and HP Spare Key)
HP Device Access Manager
HP Power On Authentication
HP Fingerprint Sensor
Other standard security features
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
SATA 0 and 1 port disablement (via BIOS)
RAID (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
Specification
Power supply
Adapters
HP Smart 45 W External AC power adapter
HP Smart 45 W External AC power adapter 2-prong (Japan only)
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP 45 W USB Type-C adapter
HP 65 W USB Type-C adapter
note: |
Power cord
1.0 m (3.28 ft) - Duckhead power cord with 2-wire plug (Japan only)
1.0 m (3.28 ft) - Duckhead power cord with 3-wire plug
1.8 m (5.9 ft) - Duckhead power cord, 3-wire plug
Primary battery
HP Long Life 3-cell, 50 Wh Li-ion
note: Supports HP Fast Charge
note: |
Battery life
UMA graphics
Up to 17 hours and 15 minutes (Intel 8th generation CPU and 3-cell 50 WHr battery)
note: |
Specification
Touch
Starting at 1.51 kg (3.32 lb)
Non-touch
Starting at 1.78 kg (3.94 lb)
note: |
Dimensions (W x D x H)
Touch
32.61 x 23.42 x 1.80 cm (12.84 x 9.22 x 0.71 in)
Non-touch
