HP ENVY x360 - 15-bp010ca Product Specifications
1UG61UA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 620
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI v2.0a; 1 headphone/microphone combo
35.97 x 24.88 x 1.96 cm
2.15 kg
45 W AC power adapter
3-cell, 55.8 Wh Li-ion
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP ePrint; HP Orbit; HP Recovery Manager; HP Support Assistant
Pre-installed software
Netflix
Country: Flag United States
